Cell Phones Logo
Question about Nextel i836
How do I get my nextel !570 off airplane lock
Posted by mimmy952 on
How do i turn iy of
Menu -> Settings -> Advanced -> Airplane Mode, and set it to Off.
Mark
Motorola Support
Feb 06, 2014 • Nextel i265
9helpful
3answers
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
2helpful
I can't turn off the airplane mode
I'd have to know the phone model for this. However, this may work. With the phone on and ready to make a call, hold down a number key, 1 through 9. You should have phone numbers programmed into them. Hold down for about 3 seconds. The phone should advise that you are in airplane mode and do you want to turn on transmitters. Say yes and that's it. If you have a Nextel phone, you may have accidently held the "power on" button too long. That will cause the phone to come on in airplane mode.
I don't know how to turn off my airplane mode
If it's a Nextel phone , try this.
Go to:
Menu:
Settings:
Advanced:
Transmitters: (select) then off.
6helpful
Can't get phone out of Airplane Mode.
Remove the battery and SIM card. Put battery back in and start up. If should say "insert SIM". Then remove the battery and replace SIM. The you will be prompted to "Allow Transmissions". Click Yes and then you're all set. I hope this helps. It worked for me.
Screen does not light up
you turn on airplane mode by holding the on/off button too long when turning it on. no more that 5 seconds. tough to take the screen apart, go to a nextel store, they have the tools.
Airplane mode
Sounds like your phone is damaged .. your best bet is to take it to a service center for repair
Dec 02, 2007 • Nextel i830
1helpful
3answers
Airplane mode
I have found that if you press and hold the power key when turning on the phone, it can activate the airplane mode. Try to press and release it when turning it on to stop this problem.
Nov 17, 2007 • Nextel i730
1helpful
Airplane Mode..
Here is the link to the user manual; http://www.nextel.com/assets/pdfs/en/support/guides/phones/i265/ug.pdf Check page 119 of the manual (129 of the pdf)says: "Sometimes you may want to have your phone on,but turn off its ability to make and receive calls, such as when you are on an airplane. To set your phone so that it cannot make or receive phone calls, Direct Connect calls, Group Connect calls, Talkgroup Calls; or transfer data: 1 From the main menu, select Settings > Advanced > Airplane Mode. 2 Set this option to On. This icon U appears. Note: Pressing p for more than 5 seconds also turns on Airplane mode. To restore your phone?s ability to do all these things: Set this option to Off." Hope this helps :)
Jun 29, 2007 • Nextel i265
Top Nextel Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
