Go to this website and you can download Sansa Media Converter for free.
Good Luck, I hope this helped,
Please rate me, Thank You
http://www.brothersoft.com/downloads/sansa-media-converter-software.html
You can go to demonoid.com as well click torrents the type in sansa media converter and you can the software free from them as well
they have every type of software imagineable!
SOURCE: Sansa Media Converter
Check this site
http://isohunt.com/torrents/Sansa+Media+Converter+1.3
http://www.mininova.org/tor/546074
http://www.fullreleases.com/NewMembers/full-ddl-download-serial-crack-torrent-new-Sansa-Media-Converter-2.php?search=Sansa+Media+Converter+2
I hope this helps
Thank you
Computerrep
SOURCE: sansa e250 media converter
Yes. The program is available for download from the Sandisk website.
GO TO SANDISK.COM.
Type your model number into the search box in the upper right hand side. (example: E250)
Click on the photo of the model you purchased.
Scroll down and you will see on the right side- "Support, Docs and more"-
Click on that-
Then click on the "Sansa Media Converter"-
It will then take you to a registration page. You can skip this by clicking the "Skip registration".
Now you will be at the download page.
If you have any trouble getting to this, please contact Sansa at their toll free phone number: 1866SANDISK.
SOURCE: sansa c 240... how do i download media converter?
You don't need to Get the Sansa Media Converter to Transfer song on your player. the Sansa Media Converter is used to transfer photos and videos on the Sansa.and to transfer song on the Player this is what you need to know.
the Sansa has two modes wherein it may connect to the computer, the MSC (Mass Storage Class) mode and the MTP (Media Transfer Protocol) mode. If you are transferring un-licensed, non-protected songs, you may transfer them using the MSC mode by simply copying them on to the Sansa. This mode also allows you to use the player with Audible files. If you are transferring music that you have purchased or music that are licensed and/or proctected, you would need to use the MTP mode. To transfer these files, you would need to use Windows Media Player 10 or some other Music Softwares such as Rhapsody and Napster.
If you add songs to the player in one mode, then switch to the other mode, you will not be able to see the songs from the previous mode, though the space used on the player will still reflect their presence. If you cannot see your songs on your PC in one mode, please try viewing them in the other. In order to change the USB mode of the player, you must power the player on and go to "Settings." Under "Settings," there should be a "USB" option. It would then give you the choice to change it from "Auto Detect" (MTP which is also known as Playforsure in other Sansa) to "MSC (Also known as Rhapsody in other Sansa)."
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the "Sansa C240" drive for your Sansa.
3. If you see 3-4 Folder there, click on Tools choose File Opdtion, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
If you still need the media converter...go to utorrent.com to download there software and go to this website...
http://search.utorrent.com/search.php?q=sansa%20media%20converter&e=http%3a%2f%2fwww.mininova.org%2fsearch%2f%3futorrent%26search%3d&u=1
SOURCE: Sansa Media Converter will not convert MP3
Duh!
I went back and re-read the manual (phamplet) I downloaded the MP3 files directly into the e200. Works great now.
Like I said. DUH
SOURCE: sansa c240 media converter free download website
http://www.sandisk.com Visit the website and from download section choose th required device and you will have it.
