WATER PUMPS ARE DESIGNED WITH A "WEEP HOLE" IN THE BOTTOM OF THE PUMP. THIS WILL LEAK IF THE BEARING OR SEAL IS FAILING.
I HAVE A FEELING THE SMOKING IS DUE TO THE COOLANT DRIPPING ONTO A HOT EXHAUST MANIFOLD OR PART
,Get rid of it its a lemon.
Theres a leak in ur hose, maybe the thermis stat, or it might have a clog in ur system... try new cap also
My 1999 chevy malibu is leaking coolant and smoking by the resavoir and overheating. What could be causing this
I recommend:
Change
document.onload += __init2();
function tryRTE2(tryCount) {
if (tryCount > 20) {
//alert('ERROR: failed to initiate rich text editor, please reload this page');
return;
if (typeof frames['Post_2'] != 'undefined' && typeof g_rte_2_hcontent != 'undefined') {
if (typeof frames['Post_2'].document != 'undefined') {
//document.getElementById("temprte_2").display = 'block';
write_rte_2_editor('Post_2', '', '500px', '320', true, false);
if (document.getElementById("temprte_2") != null) {
document.getElementById("temprte_2").style.display = 'none';
return;
tryCount++;
setTimeout("tryRTE2(" + tryCount + ")", 20);
function __init2() {
init_rte_2("rte/", "/");
var ua = navigator.userAgent.toLowerCase();
var ie = ((ua.indexOf("msie") != -1) && (ua.indexOf("opera") == -1) && (ua.indexOf("webtv") == -1));
if(ie) try{document.execCommand("BackgroundImageCache", false, true);}catch(e){}
//try for 2 seconds, every 100ms, to initiate, if rte iframe loaded.
setTimeout("tryRTE2(0)", 20);
/*var _timer = setInterval(
function() {
clearInterval(_timer);
return;
var iFrames = document.getElementsByTagNames("iframe");
alert(iFrames.length);
if (typeof frames['Post_2'] != 'undefined') {
write_rte_editor('Post_2', '', '500px', '320', true, false);
tryCount++;
}, 100);*/
What is this?
Solution
Clarification Request
Post Answer
