Apple iPod nano Logo
Posted on Dec 12, 2009
After charging and unplugging from the USB port of my computer, the iPod screen goes blank and won't come back on. I have tried resetting, but no luck. Just in case it matters, I had not used it for quite some time prior to recharging this time.
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
11289
Points
51
Have you got a normal wall charger is so it is smarter to use that, becuase when you charge the nano or any ipod for that matter, it slowly makes the battery life shorter so i suggest start charging from the wall charger, but it might be too late but give it a go if you have one hope this helped
Dos not work
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
hope this helps
tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 • Computers & Internet
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
1helpful
2answers
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
Reset iPod
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
How to use an ipod shuffle charge
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
1helpful
2answers
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Ipod is just determined not to charge
Unplug and plug it back in, if not try resetting than plugging it **to reset: hold the menu and the center button until the apple logo comes up
2answers
Does not charge
Well, it sounds as though your battery is shot. However, before completely giving up i would restore the ipod in itunes and then let it fully charge. After it says "fully" charged, disconnect and test. if it still has no charge, reset it by holding down both the menu and center buttons until you see an apple appear on the screen. If after these steps it still does not charge i would check into getting a new battery either through iPodbatterydepot.com or by calling apple tech support at 1-800-APL-CARE (1-800-275-2273) Good luck
5helpful
5answers
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
2answers
Ipod won't charge
It means the hard drive is crashing. If it's clicking it means there is a problem with the hard drive. Try restoring your ipod or reformatting it.
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
OR TRY THIS
iPod's battery doesn't charge Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port iPods that connect to USB ports require a high-power USB port. Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or FireWire port on the computer.
FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip: Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
You are using Windows 2000 If you use your iPod with a computer using Windows 2000, see document 304801 "iPod: Proper charging procedures for Windows 2000" for steps on how to keep iPod charging.
There are too many devices in the FireWire chain Your computer can provide power to FireWire devices that don't have their own power sources, such as hard drives and cameras. If there are too many of these kinds of devices connected to your computer, iPod may not be recognized.
  1. Disconnect all devices from your computer's FireWire port(s).
  2. Connect iPod to the computer's FireWire port using the FireWire cable that came with iPod.
If this resolves the issue, consider purchasing a powered FireWire hub to connect your nonpowered devices to. These hubs are available from the Apple Store.
iPod is locked up If iPod is locked up it will not charge, reset iPod. When you reset iPod all your songs and files are saved, but some customized settings may be lost. Tip: iPod will not wake automatically if you connect to a 4-pin FireWire port. Press the Select button (center of wheel) to wake iPod.
Faulty cable If something is wrong with the FireWire or USB cable that came with iPod, it may not supply any power to charge the battery. Note: Only iPod models with a Click Wheel can get power from a high-powered USB port using the supplied cable (includes iPod mini, iPod (Click Wheel), iPod photo, iPod with color display, iPod nano, and Fifth Generation iPod).
  1. Make sure you are using the cable that came with iPod. Some third-party cables may not work properly with iPod.
  2. Make sure nothing is in or blocking your computer's FireWire or USB ports.
  3. Check the connections to make sure the cable is completely plugged in.
  4. Try another known-good FireWire or USB cable if available.
If this resolves the issue your FireWire or USB cable needs to be replaced. You can arrange for replacement at the iPod Service Website.
Faulty port on the computer If something is wrong with your computer's FireWire or USB port, it may not supply power to iPod. Note: Only iPod mini can get power from a high-powered USB port using the supplied cable.
  1. Check the connections.
  2. Try another known-good FireWire (or high-powered USB) port on a different computer if available.
  3. If you do not have access to another computer, use the Apple iPod Power Adapter.
  4. Plug in one end of the FireWire cable to the Apple iPod Power Adapter and the other end to your iPod.
  5. Plug the Apple iPod Power Adapter into a working electrical outlet.
  6. If you have an iPod (with Dock Connector) model, connect the FireWire end to the Apple iPod Power Adapter and the dock connector to iPod. Warning: Never plug the dock connector end of the FireWire cable into a computer's FireWire port.
If this resolves the issue, consult your service and support guide to see how you can have the computer's port repaired.
Faulty Apple iPod Power Adapter If something is wrong with the Apple iPod Power Adapter, it may not supply power to iPod.
  1. Try another known-good electrical outlet.
  2. Make sure all the connections are good. Try disconnecting and reconnecting all connections to make sure they are snug.
  3. Try another Apple iPod Power Adapter if one is available.
  4. Try connecting iPod to a computer's FireWire port using iPod's FireWire cable.
If this resolves the issue the Apple iPod Power Adapter needs to be repaired. You can arrange for repair at the iPod Service Website.
You might consider additional troubleshooting steps for the Apple iPod AC Adapter before having it replaced.
Faulty dock connector or FireWire port on iPod If something is wrong with iPod's FireWire or Dock Connector port, it may not supply power to iPod.
  1. Make sure nothing is in or blocking iPod's FireWire or Dock Connector port.
  2. Check the connection to make sure the FireWire or Dock Connector cable is completely plugged in.
If this did not resolve the issue iPod needs to be repaired. You can arrange for repair at the iPod Service Website.
Related Terms: charged, dead, die, dying, drained, draining, drain, drains, frozen, freeze, freezes, freezing
Keywords: ktech kipod kipodwin kipod1 kipod2 kipod3 kipod4 kipod5 kipodphoto kipodmini kipodmini2 kshuffle kipodnano kipodnano2 kshuffle2 Did this article help you?
It solved my issue...
Tell us what works for you.
It's good, but...
Report typos, inaccuracies, etc.
It wasn't helpful...
Tell us what would have helped.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
