Philips 55PP9401 55" Rear Projection Television Logo
Posted on Dec 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My picture has red ghosting. I tried to perform
My picture has red ghosting. I tried to perform the manual convergence for Red but when I try to use the remote to converge nothing happens. The remote works fine though. Any ideas?
Anonymous
Level 3:
  • Master 541 Answers
  • Posted on Dec 14, 2009
Anonymous
Master
Level 3:
Answers
541
Questions
Helped
126620
Points
1217
This set has a bad convergence amp ic. This can be a complicated repair involving in depth convergence adjustment. You may be better off having a shop check it out for you. Thanks for using fixya.
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
RED GHOSTING - tried convergence adjustment with no luck in moving the red ghost
*Screen Looks 3-D
*Colors wont align
Problem #2
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Red in picture creates a ghost picture
Sounds like a loose connection in the convergance amp ic's
4helpful
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
1helpful
TV convergence problem
convergence circuit overhaul needed==replace stk-392-560 ic's.check alignment.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
