Hi there, Washing machine wil 145 PROBLEM. i PUT A MICHINE TO RUN TODAY: BIG NOISE, BURNING SMELL, SMOOKE COMING OUT, AND PLASTIC BURN AROUND THE DOOR, WHY?
Posted by nadege_deria on
Anonymous
    New Friend:
    Problem Solver:
  • 7 Answers
Not a good sign but hurry and buy a new one because it can cause a spark which can heat up your wall and what do ya know ur home is burning
Posted on Dec 12, 2009
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
I have a GE washing machine model # WCSR2090DAWW and today I went to put a load of clothes washing. It filled the tub up with water like normal and then went into soak mode. The problem starts when it...
Possible that some item of clothing is jamming up the drive to the tub. The burning smell are the motor windings reacting to the excess of electricity flowing thru them before they burn out.
Apr 02, 2017 | GE Appliances 3.5 cu. ft. King Size...
Hi i have a dewalt DC 988 combi drill, 4 years old. its starting to have a burning smell when used what are possible problems and solutions?
It all depends on what is burning I'm afraid. When in use, run your hand around the back of the machine and handle area to see if anywhere in particular is getting hot. On the older versions of these (DW988) the leads leading from the switch to the brush holders would overheat and burn, also causing damage to the brush holders themselves. Is there any smoke coming from the rear vents, if so you wil probably find it is a motor problem and the smell would be the insulation burning off the armature. The only other thing to check would be to make sure the battery isn't shorting and getting hot, as this could also cause damage to the switch and vice versa.
Feb 10, 2010 | Dewalt DC988ka 18 - volt XRP 1/2''...
Stopped working, burning smell, clicking noise while plugged in.
have a technician check it out. burning smell is always fire hazzard. A connection may have gone loose or connections are soaked.
May 12, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Washing machine started making noise in spin cycle and then there were fumes
The belt is loose and slipping. They were probably, black and smell like burning tires!
Just in case it was a wire burning!!
Call service this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Washing machine noise
my washing maching will not spin out all the water in the spin cycle.
Dec 20, 2006 | Hotpoint VLXR1020A Top Load Washer
Washer emitting burning smell and smoke on fast spin
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
Oct 28, 2006 | Hotpoint WMA35 Front Load Washer
Computers & Internet Logo
k24674
