Yes if you have the code and the display reads error then you need to reset the audio unit. to reset you can disconnect the neg and pos battery cables hold them so they are touching each other for approx 30 seconds. reinstall cables and the error message on the audio unit sounds be cleared and you can now enter you code. if it still reads error then there may be internal damage to the audio unit- hope this helps
Have you tried disconnecting the battery for at least 30 seconds? Other than that, the computer can be reset using an OBDII code reader plugged into your DTC socket under the dash (Autozone will do that without charge). That should move the radio from Err to Code.
