Tip & How-To about Ford Explorer
If your odometer will not light up or it comes on and off them you most
likely have a cold solder joint and can be fix with basic soldering
skills a soldering iron and solder.
Remove your instrument cluster and
check the solder joints on the back of the cluster main board. You may
have to flex the board to see the cracks in the solder. i have found
the main connector soldering joints to be cracked for the display it self. any in question re solder while you are there.
simple cheap fix and not very time consuming at all.
