Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
Posted on Dec 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag gas oven has an F3 code and beeping. Model # CGR3740ADW.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Dec 11, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2971265
Points
24702
Hi. This code is the result of a shorted, or open(circuit) oven temperature sensor device. You will need to Check the sensor harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
F3
F3
or
F4Shorted or open oven temperature sensor (RTD)Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Maytag Range / Stove / Oven Fault Codes#ixzz1kNxJMSok
Hope this helps you :)
F3 appears and it beeps when I try to preheat the oven
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Oven beeps and display read "F3". what does this mean?
Hi dpaulthomas,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to resolve this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
3helpful
2answers
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Maytag model CWG3100AAB error code f3
when the clock goes off on my oven the oven stopsand will only come back on when it is cooled off.
My Magic Chef gas oven is flashing F3 and beeping. The model # is CGR3740ADW. I think that means a bad sensor, but how do I figure out which sensor and how to replace it? If I had some diagrams or...
There is only one sensor. Look inside the oven on the top right or left rear. The sensor is about 3 inches long,metal and about the size of a thin pencil. It will be held in by one or 2 screws. Unplug the range. Remove the sensor and disconnect the wires. Use a volt meter set for ohms. It should read 1100 ohms plus or minus 50 ohms. If it reads more or less replace it.
If you have no meter just replace the sensor. It is bad if the control says it is bad.
Dec 11, 2009 • Ovens
1helpful
We have a gas maytag gas wall oven that is getting f3 and f5 error codes
F3
F5
Watchdog and hardware conflict
Replace clock (ERC).
2helpful
2answers
Flashes f-3
you have a bad oven temp sensor probe
8helpful
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
