Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Leading cause of paper
jams is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
Remove the sheets of paper from
the feeder.
Grab a flashlight and look
inside the feeder for any debris or foreign objects.
If you're willing and
physically able, you may also carefully turn the printer over. Any debris
should just freely roll out from the feeder.
If feeder is clear, place the
printer on the table. Open the printer cover and remove the cartridges.
Check the cartridge area for
any obstructions in the paper path.
Close the printer cover.
Re-brick your printer by
pulling out the power supply - the black box where the power cord is
plugged into. Re-plug after 30 seconds.
When the printer turns on,
reinsert the cartridges and load some paper. Try to print again to verify
that the problem is fixed.
If that doesn't help, try to re-seat the cartridges by removing and re-inserting them into the printer. Make sure they are properly seated and secured. I hope this helps.
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
Hi, Here is a guide of all possible paper jam locations on the X340 printer. http://bit.ly/cS4lpm If still no paper is found on any of those places then the printer has a faulty sensor. Depending on the paper jam numeric error is the sensor that may be failing.
