Question about Sony KP-65XBR10W 65" Rear Projection Television
Screen had red/orange lines, then the screen went all orange
Screen had red/orange lines, then the screen went all orange sound is OK. The standby light blinks 5 times, then pauses
Tried all vidio channels
Picture seem ok for the 1st 10 seconds then turns orange
Posted by rbs3657 on
Dave Naylor
  • 834 Answers
Your read crt is shorting out sorry to say the crts are no longer avail, you can have them rebult but on a projection set they will never look good due to phosforous burn I would say it is time to retire the set
Posted on Dec 11, 2009
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
58" Sony HD Projection
go to wwwsomelifeblog.com/2007/06sony-projection-tv-red-line-repair.html
Sep 30, 2009 | Sony KP-51HW40 51" Rear Projection...
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
I have a Pioneer Plasma 434PE and was watching tv when the picture went purple with grain line and then made the screen go blank and now stuck in standby mode flashing red, power comes on but goes back to...
its likely that eith er the y sus or x sus pcb have gone faulty or it could be the main or power supply pcb. if all else fails, check voltages and if they are ok from each point , you need to replace the plasma panel.
Jul 05, 2009 | Televison & Video
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
TV screen went black, sound ok, red light blink 5 times
Be sure its blinking 5 times, count after it cycles the first time through the red lights. If it is fact 5 times, that is a lamp driver error.More likely it cycled 4 times, which is common on this model, if that's the case, then it's the fan. Most likely the large one in the rear...It's an easy fix, just pull the back off and replace the part.
Sep 14, 2008 | Sony KDS-R50XBR1 50" HDTV
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KP-65XBR10W 65" Rear Projection Television Logo
300 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
