Computers & Internet Logo
Anonymous Posted on Dec 11, 2009
Foxconn 648fx4mr-es boots up no display
I have a foxconn 648fx4mr-es its working fine but now when i push power button the cpu fan is running, hdd, odd etc but no display, i tried my agp card on other board it works as well the other components its working, there is power going in to the board but just no display, need help
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Dec 11, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2758
Points
22
If there are no beep codes, it will be hard to troubleshoot this. It could be bad RAM. Try using only one stick at a time. Also, disconnect all USB peripherals (especially printers and scanners). Try disconnecting your keyboard as well (BIOS should give a "keyboard error" message). The problem is most likely RAM, CPU, or the motherboard itself.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9587
Points
U take M.B outside .then u install cpu , agp, ram , power supply ,finish u running . please u try.
8helpful
2answers
Want boot up. Whern you push the power on button, one light on the CPU comes on and all fans come on. There is one beep when you push the button. The CD drive has power. The moniter does not come up. I...
it means machine working fine but display problem check it your RAM check with a soft cloth may monitor is also avilable or check behind the VGA cable proper connect it or not
I was running a gigabyte MB ,.then powr supply failed baddly,.. I purchased a used foxconn MB and diffnt PSupply,..I put the CPU on foxconn MB and mounted in old case w/ what I think is good PSupply,.. but...
did you connect the cpu fan and fan 1 power feeds in on motherboard ?
from
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket478/661FX4MR-ES/manual/English/661FX&648FX4MR-Eng-easy%20guide-09-04-04.zip
Systemax Ascent HA3200 RTS won't boot - fans come on - no display
The motherboard seems OK as it is displaying signs of life. The Monitor should display something before booting up, which it is not.Please do the following. 1. Remove the RAM and reinsert the DIMMs into their sockets and boot up. 2. Disconnect the HDD data cable from the HDD and the motherboard and reconnect. Boot up. 3. Disconnect the monitor and reconnect. Boot up. At boot up press F2 and set the PC to default settings. Boot up. Later when you want to apply your settings, keep noting down what you did when. Just in case.
1helpful
2answers
After psu burned out , can't boot computer with
see your cpu fan connector, weather it is connected properly. to check wether psu is working properly, short the black n green wires present in the psu's mother board connetor by using a single strand wire, and switch on. if the fan rotates there is no probs with the the psu. then u will have to replace the motherboard
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Cannot shut off & no display
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
2answers
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
1helpful
Long beep when power on PC
Usually any kind of clear distinctive beep while booting up is an error code. If you get a long beep with no display then it could be the memory or CPU. Check to make sure all of your cards are pushed in all the way. Just take your hand and push on your memory, cpu, and other cards gently but firmly to make sure they are seated. Also make sure that everything is connected. You may have missed connecting power to something.
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
Grand Canyon Tech
Grand Canyon Tech
