Question about Amana Refrigerators
Freezer coil freezes up, refrigerator gets warm. Defrost the coils, works fine and then freezes again in few days. Could it be the defrost control board, t-stat, or heater defrost? Which is more likely to have failed. Is there a test I can perform? Any information you can give me would be great. Neena
    Sergeant:
  • 295 Answers
Heaters and defrost timers, and thermal cutouts should be changed at the same time.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Oct 19, 2017
6ya staff
SOURCE:
MARK FISHER
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
Anonymous
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
Anonymous
SOURCE: GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Posted on Jun 25, 2008
ryeisenman
Richard Eisenman
  • 9 Answers
SOURCE: cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
Anonymous
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
Norcold 1200 fridge only getting to 50 degrees will work fine for a few days then get warm if i shut it off for a few hours and turn it on again it will cool for a couple of days then problem retur
Sounds like your defrost cycle has failed. Since the unit is running fine for a while before warming up, this can rule out your circulating fan. Your defrost cycle is operated by a defrost timer or your motherboard depending on the age of your refrigerator. When your refrigerator goes into defrost, it turns on an electric heater that melts the ice from your coil in the freezer. When your defrost time or electric heater fails, it allows ice to build up on the coil in your freezer which blocks airflow which causes your cooling compartments to not maintain temperature. Hope this gives you an idea what to look for and a guide on where to start looking
Jan 20, 2018 | Refrigerators
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
The fridge will operate fine for about 2 or 3 days and then the inside will get warm and melt all the ice. I will unplug the unit for a few days plug it back in and it will operate fine for a few days and...
Sounds to me like you have a bad defrost timer. As the freezer is working correctly, it is building ice on the evaporator. It sounds like it does not go into defrost, thus freezing up the evap coil, and stopping the evap from cooling the surrounding air. Hope this helps
Jul 23, 2010 | Frigidaire Refrigerators
Freezer coils freeze (ice) and refrigerator gets warm --- then I blow dry coils and it works for 4-5 days b4 freezing again model is FRT17G5C
One of your components in your defrost system is defective. It may be either the heater, control or termination. Your model will typically have a bad defrost termination. But you would need a multimeter to know for sure. You can do a visual inspection on the part to see if it got moisture in it and "popped" Hope this helps _MJ_
Jun 09, 2010 | Refrigerators
Freezer coils freeze up, refrigerator gets warm
You first need to check your defrost heater for continuity if none this is your problem if it has continuity it is good and you will need to replace your adaptive control board part # AP4010220 ? Enter your complete model # at www.appliancehelponline.com for illustrations and correct parts. The model # listed should have a few more digits thats why I ? the part # I listed. There is also a troubleshooting page that can help walk you thru testing these components.
Mar 28, 2010 | Amana ASD 2624 Side by Side Refrigerator
The freezer on our kenmore fridge keeps freezing up and then the fridge doesn't cool. It's a bottom freezer style. We have to unplug it and let it unfreeze in order to get it working properly again but it...
defrost problem, check defrost thermostat on evap coil by removing the back panel in freezer for continuity, if open, replace. check heater in the same fasion, if open, replace. if both are ok, replace defrost timer, or adaptive defrost control.
Jul 01, 2009 | Refrigerators
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Coils In Freezer Keep Freezing
check continuity thro defrost heater and check thermal cutout in series with the defrost heater
Aug 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Bottom freezer coils freezing up
DEFROST PROBLEM CHECK YOUR DEFRST HEATER,DEFROST T-STAT=LOCATED BEHIND THE PANEL BOTH ARE LOCATED ON THE COIL WITH A OHMETER OR DEFROST WITH HAIR DRYER IT WILL HELP FOR 10 DAYS OR SO.
Jun 25, 2008 | Amana ABB1927DE Bottom Freezer...
Magtag french door with water and ice despenser door with auto defrost keeps freezing up.
You have a defrost system problem related to the timing device, heaters, or defrost thermostat. Coils for the freezer are inside the back wall and defrosting the surface does not get ice out of coils.
it will not get any better until you have it serviced. This is not normally a project for a do-it your selfer.
May 28, 2008 | Refrigerators
Refrigerators Logo
161 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
