Question about Canon LBP 660 Laser Printer
Correct instal of toner + how to print test page [canon LBT 660]
Just replaced the toner unit, but will not print. is there a 'trick' to installing the toner? How can i print a test page?
Thanks,noel.
Posted by rssmacca on
Anonymous
    New Friend:
Help pleas draivers canon lbp-660 windows7
Posted on May 23, 2010
Anonymous
  • 35 Answers
Install your printer driver before.It supported driver win 98.then you can print a test page.
Posted on Dec 12, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
E500 canon not print
Make sure the correct driver is installed. Then attempt to do a test page. If the message to print is reaching the printer some printer light will flash to indicate such. If it flashes but does nada you may have a defective, electrically bogus print cartridge. If I remember correctly on previous Canons, the ink cartridges were only ink containers and not electrical units like on HP printers. If so, forget looking at the cartridge area - the issue could be either a mechanical one or one involving the printers electronics.
Sometimes printer electronics get bogged down and what you need to do is completely disconnect unit from power source and allow the printer to boot up anew like a computer. Often that does the trick.
Apr 27, 2014 | Computers & Internet
After changing toner it displays the call service 7410-0066564
Error 7410 - Drum unit non- installing error
The drum unit is not installed or not installed properly.
Install the drum unit (See page P.1-5-10 of your operation guide). See image below.
The numbers after 7410- are the number of pages printed on this printer.
Nov 23, 2011 | Kyocera FS-3900DN Laser Printer
I am using canon 4200 printer. even deep cleaning did not solve my printing problem. what should i do. advise appreciated.
if its not printing just test the test page printing.If even u didnt get the test page check whether u get the correct drivers for ur printer. Then chek the toner for powder and check wheter the toner is defectd
Get the exact drivers here for ur printer: software.canon-europe.com
Jun 07, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
Brother MFC 6800 Drum replaced, now prints blank page. Plastic sheet was spit out indicating correct install. Same toner cartridge will work if old drum re-inserted, but print quality is bad, as drum worn...
Here is a link to the user manual check page 187... and buy a new toner... sometimes the toner runs out and the unit does not alert you... if the toner does not fix the issue but the old drum still works... then your new drum is a dudd and needs to be changed...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 16, 2009 | Office Equipment & Supplies
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 9700
Remove your drum unit and you will see on top of where the drum unit sits inside your machine is a piece of glass(inside the machine). Wipe the glass with a soft dry cloth. If this do not work, remove your toner cartridge and see if the toner is spread evenly on the cartridge.
Mar 17, 2008 | Brother MFC 9700 All-In-One Laser Printer
Canon LBP 660 Laser Printer Logo
234 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
