None of our faxes are going out and we receive error number 87
This is a Canon Super G# and all of a sudden none or our faxes are going out.
Posted by babiesdocs on
Norman Davis
  • 622 Answers
Set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 12, 2009
Canon ir 3300
Try the following:
1) check for toner levels (may need new cartridge)
2) check for paper on the tray
3) try printing a copy from that device.
Dec 30, 2013 | Office Equipment & Supplies
Can't send or receive fax [email protected]
Check the cable, i.e. plug an analogue phone into the cable and listen for a dial tone. If none, are you plugged into a digital line?
If a dial tone is heard, is it an intermittant dial tone (message waiting) because this can stop the fax from working. If so, resolve this and try again.
Do you need to dial a number to get an outside line? If so this needs to be entered before the fax number on outgoing faxes.
Nov 17, 2009 | Canon MP830 All-In-One Printer
Hi,my problem is that my printer suddenly stop printing, the alarm light is blinking and the number 2 and letter E appears blinking in the printer. any idea what that mean.can you help me with this. thank...
There are a number of reasons for the E2 error. Go to the Canon site at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12764
In FAQs ask for a search on "error e2". Check the various suggestions. If none of these work, let me know and we can try some other solutions to your problems. Thanks.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cant receive faxes
plz check all cables properl there might be damaged one ... then check you fax machine ink ..if none seems to be the problem the get it once serviced it will get back on working
Aug 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
0009: Error during TX message
Guys,
I got the same problems and then I contacted our PSTN provider and they configured the route. Now it is working fine!
Jul 18, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Re; Response for faxing problem
my canon mp780 fax will not fax all my pages. one page my go threw while i refax and none will go. my error report shows ng for result.what does that mean??
Jun 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
k24674
