Question about JVC KD-LH7R CD Player
How to take a cd player out of a mercedes aclass
Posted by martindungey on
xxxxxx xxx
  • JVC Master
  • 5,023 Answers
See if you can find your instructions here
http://www.fitaudio.com/
Posted on Dec 10, 2009
Cd player plays but there is no sound,WHAT ARE YOUR SUGGESTIONS?
blown fuses to the amplifier / disconnected wire /worn or snapped belt inside or a clip broke of the wheels that make contact
Feb 27, 2015 | Mercedes-Benz Mercedes E Class E320...
My cd stuck in the cd player, I have a ml320 Mercedes benz 1998 where can I take it to be fix?
u can go to a repair shop - tape/electronic shop or have the cd player removed at a workshop after which u can take the CD player to a repair shop
Sep 30, 2013 | Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome...
Cd player is reading disk error when i put in cd.
Is it a burned cd is so maybe its not the right format. If not then I would get a cd player cleaning disk kit to clean laser in cd player.
Sep 27, 2013 | 2007 Mercedes-Benz S550 Sedan
My mercedes 2007 s 550 cd says cd error after cd is scan
If you take your car to a MB dealer, they can do a test of the CD system. Unfortunately, the few times that I have seen this problem, it has required replacement of the VERY expensive COMAND module.
Feb 01, 2013 | Mercedes-Benz Cars & Trucks
My mercedes s550 cd player scans cd then says dics error
same with my problem .it's mean the eye laser is bad. you can't fix it.i have to go to the ebay buy the use one for $800 dollars. mercedes s550 tech such...too many problem. my is 65.000 mile i already replace lower arms control on 2 side A/C blower fan 2 struts suspension. now is the font lelf window not working. my god. i think the old toyota corola the tech is better then. (S550)
Feb 01, 2013 | 2007 Mercedes-Benz S550 Sedan
Battery went dead had to jump start, now cd player wont work on 2006 mercedes
It should be in the manual supplied with the car. If not call mercedes and give them your vin, reg private detail etc and if you get a nice person,problem will be solved. It happen to me, but not a merc that you gladly own. I'm n battery not sure about this advice but a merc uses a high voltage and you may need a new battery.
Dec 20, 2012 | 1995 Mercedes-Benz E-Class
ML Mercedes cd player
If you have tried multiple cd's to no avail, the problem is in the unit. To fix inexpensively, contact Newton Auto Haus in Newton NC, and supply the proprietor with the model # of your unit, he will supply you with a used, (in good condition) replacement. He specializes in Mercedes and has a great reputation.
Jun 19, 2009 | JVC KD-LH7R CD Player
Mercedes a class gearbox fault.no gears
If you take it to mercedes they will charge £3500 and will replace the gearbox, Alternatively you can change the shifter valve £25, new sump and filter as they have changed, fit a magnet inside the gearbox as the early A didnt have one. Fresh oil and see how you get on, the control unit for the gearbox sits inside the gearbox £1000 roughly for a new one but it has to come from mercedes in germany where it is coded to your chassis number, 2nd control units are not an option!!!!!!!
jib
www.mercanic.co.uk
Oct 18, 2008 | 2003 Mercedes-Benz C-Class
JVC KD-LH7R CD Player Logo
85 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
