Question about Hoover Freezers
It makes a very loud noise most of the time - Hoover Freezers
Posted by barnes917 on
Anonymous
  • 291 Answers
First determine if the noise is from inside or outside of the freezer. If it is louder inside, and you have a frost free freezer, it is usally your evaporator fan motor. If the noise is behind and underneath you unit, then you need to pull the backing plate off, if it has one and determine if the noise is coming from the condensor fan motor, ( if it has one), or from the compressor itself. It usually is compressor and is definitely not worth repairing unless it is under a 5 year sealed system warrantee. Good Luck
Posted on Dec 10, 2009
My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Upright whirlpool freezer make loud noise when it comes on
This noise is the fan motor going bad because a bearing is worn out. You need to replace the fan motor before the compressor goes out.
Aug 28, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
My whirlpool ice maker makes a noise like its growling or like a
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 15, 2009 | Whirlpool Freezers
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
Woods Freezer Makes Loud Vibrating Noise at 10pm each night
sounds like either your compressor is loose and just rattling or the compressor is off balance and its rolling around inside the seal can.  take a look at it when it is making the noise.   put your hand on the compressor (careful   might be hot)   if it feel like it running smoothly then i would call an electrician cause that kinda puts me out of ideas without being there...  sorry
Good luck
Jason
Jan 15, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
Freezers Logo
198 people viewed this question
Top Hoover Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hoover Freezer Expert? Answer questions, earn points and help others
