remove all the usb connection to the computer and insert one by one and isolate tthe non recognised device cange the usb por and reload the drivers while conectin you will see adding new hard ware and the name of the device if you dont see and it shows unknow device the udb device is fried
i) try to connect pendrive to the usb ports present at backside of ur computer tower instead of usb ports present at the front panel of ur computer...............
ii) sometimes usb ports present at the front panel ofur computer might have loosen connections............
Press and hold the button while plugging the other end of the USB cable into the YP-Z5.
When the display shows USB Connected, release the button.
The device is now in USB mode.
When through, you must safely remove the USB device.
Note: To safely remove the USB device, right click the USB icon ( ) in the bottom right of your screen, and then click Safely Remove Hardware.
Upon disconnecting the device, it will return to MTP Mode.
