Printer will not power on. Electric outlet/supply checks out fine. What else can I check
Without knowing your skill level, your best solution is to get a repair tech on site.
I would suspect that the power supply is shot. If you can get to it easily, verify the power in voltage and then the power out voltage.
However, there are many possible causes, for example, on the IBM copiers I used to service there was w fuser overtemp sensor and a fuser lamp fuse. If either of them opened, then the same failure would present itself.
I must mention that I have not worked on an IBM Copier for about 20 plus years but the design of products such as copiers demand safety cut-offs.
Don
