Question about Canon PIXMA iP1500 InkJet Photo Printer
Printer won't print. Says to contact service center for replacement of waste ink absorber.
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Posted on Dec 10, 2009
This error means that the waste ink pads have filled up to the point where the printer believes the ink will overflow and leak or cause damage to the printer.
To give you a quick primer... Every time you run a cleaning routine or printer borderless photos the printer will dump a small amount of ink into a set of highly absorbent pads that live in the base of the printer.
These pads can only accept so much ink before they become full but experience has shown that you could reset the EEPROM waste counter if you locate the appropriate codes for your printer.
I'd recommend asking on nifty-stuff.com in the forums and see if someone can provide the information and code you need.
Hope that helps.
Posted on May 21, 2009
SOURCE: Waste ink absorber full - contact service center for replacement
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
This simple power off procedure worked on my IP1500!
Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location (I used an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
Posted on Dec 22, 2008
SOURCE: ERROR MESSAGE 2
How do I change the ink cartridge for the Canon Pixma 150
Posted on Sep 03, 2008
SOURCE: The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Posted on Apr 23, 2009
SOURCE: Pixma IP1500 stops
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
Posted on Feb 13, 2010
Jul 20, 2011 | Office Equipment & Supplies
May 06, 2008 | Office Equipment & Supplies
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Mar 30, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Oct 09, 2009 | Canon PIXMA iP90 Mobile Printer
May 11, 2009 | Office Equipment & Supplies
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
1,074 people viewed this question
It says to contact service center for replacement of waste ink absorber. What service center? I couldn't find a phone number or address anywhere in the manual. If waste ink absorber must be replaced, I have no idea where to find the replacement.
