Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
Unfold the paperclip and make it as straight as possible.
Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
Remove your disc from the drive.
Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
OK. I assume the display does not say 'locked' when you press eject. A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common) The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this. A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case. Testing: Bad belt - the DVD drawer shifts a bit when the eject button is pressed. Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display. Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
hello, have you tried going into "My Computer" then right clicking on cd drive and click "Eject"? if not, try that.
if you have then take a thin paper clip open up one side of it so its straight.
After you have paper clip straighten up look carefully around the cd rom's eject button and you will notice a tiny hole.
Take the paper clip and keeping it straight slowly and gently insert in the hole and soon you will feel little resistance push it a little bit more and that should eject your CD rom.
if it opens up leave the cd rom open and reboot your laptop once and see if your drive now work normally and ejects the way it should?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
The Supersonic FC-2245 has known DVD issues and thousands were returned for credit. You may not have a solution. They are also being replaced by the FC2835
