Question about Panasonic Viera TH-42PZ80U Plasma TV
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
Posted by rwr2590 on
Paul
    Sergeant:
  • 381 Answers
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Posted on Dec 10, 2009
  • monica
    monica Oct 20, 2013
    I have the same problem with a 7 blinking light, is the floating voltage area, but is this a part that you can buy? this is for a tc-50ps14 tv
mrnmrshill
    New Friend:
Mine is blinking 7 times
Posted on Dec 18, 2011
Ravi
  • Panasonic Master
  • 1,682 Answers
Check the youtube. may be a similar issue.
Posted on Feb 07, 2016
Panasonic th-42pz80u...dead set...red LED blinks twice at turn-on...the 15v supply on pin 1 of P7 comes up for a second then shuts down
I'm no expert but I have the same tv I'm trying to fix,different problem from yours.I think you can take a resistance reading from that pin to ground and if there is a short,you can start unplugging different boards and when you have the right one the short will go away,if not its the power supply.Put in a search on google with something like board layout for TH-42PZ80U and click on the link 11th generation and you can tell if I told you right or not
Oct 12, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Tv went out itself red light ( power on off ) just blink, we can't turn on tv set neither fron remote or at the tv set
Jun 30, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I plug in my TH-42PZ80U and it doesnt turn on but a red light blinks ten times.
Apparently this common problem is due to a faulty power board. Contact Panasonic for a replacement if it's under warranty (hopefully) or a local repair shop. Good luck!
Jun 06, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My Panasonic TH-42PZ80U has a blinking light. It blinks two times.
Generally a two blink code means a faulty power supply. You can buy a replacement power supply online. I've seen them as low as around $120. I'm doing factual research for a potential class action lawsuit regarding these blinking light problems, so I'm pretty familiar with this stuff now. From most of the complaints I've seen people post, if you have a tech replace the power supply it usually costs between $450-$600 including the tech's labor time.
I'd like to hear more about your personal experience with the television. If you would be willing to share your story with me, please send me an email at [email protected]
Oct 15, 2010 | Panasonic TH-42PZ80U 42 in. HDTV-Ready...
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-42PZ80U Won't turn on
Make sure all of your connections for cable attenna or satelite are fully connected.
Dec 03, 2008 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Viera TH-42PZ80U Plasma TV Logo
4,091 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
