Check for adequate grounding of these sockets!
A good bulb that's dim usually indicates a weak or broken ground path.
You should be able to use a test lead to offer the socket a good ground. If the dash light goes off, problem solved!
Testimonial: "although this did not provide me the final solution it did lead me to the problem. Turned out broken ground wire problem solved thanks"
