Question about Toshiba Satellite A105-S4004 Notebook
Need 2 format toshiba satelltie A105 bat i cant boot form cd rom
Need 2 format
Posted by onetoufkro on
Resistance
  • 51 Answers
Try using a win xp operating cd to format
Posted on Dec 09, 2009
Recovery Issues A105-s361. Boot sequence always starts with HDD. Tried F12, tried F2 (bios). Any other way to boot from recovery disk(CD-ROM)!!
There is still a way for you to boot from your CD ROM. Just access or go to BIOS again, look for "BOOT" tab and then set the boot sequence of your computer and the set the first priority to be on the (ODD or CD DVD ROM), just make sure you put the CD ROM option at the first section and to do that, Use the arrow keys on your keyboard and highlight it and then press normally "F5 and F6" further instruction are there any way. Once your done, press F10 and select save and exit, Insert the disc on the CD ROM restart your computer at that time your computer should be booting now from the CD ROM.
Cheers . . .
Feb 09, 2011 | Toshiba Satellite A105 Notebook
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Cd-rom
Do you mean how to eject the CD from the laptop?
You just have to press a button on the CD-drive itself to release the CD.
If you need assitance, please post back more info regarding the problem.
Aug 14, 2009 | Toshiba Satellite A105 Notebook
How do i format my toshiba tecra A2 pta20e-07701qen
You have to enter bios when computer boots. Not sure on Toshiba it might be F10 or delete or F1 or f12. If all else fails try them all till you get into the bios. Go to advance and go to boot options. You have to set CD rom as first boot option and hard drive 0 as second boot option. That should let you boot from a CD.
Jun 01, 2009 | Toshiba Satellite Pro A10 Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Dics Drive Upgrade for Toshiba Satillate.
As far as i know thats impossible. Your optical diskdrive is made just for those speeds that you have on it. You cant change the manufacture settings and speed it upp, or make it to an dual layer disk.
Buy a new one whit the needs that u want and replace the old one. Its easy done and its not that expensive.
Good luck to you
Nic
Feb 04, 2009 | Toshiba Satellite A105 Notebook
Toshiba A105-S4344 DVD-ROM not working
possible a loose connection, check to ensure you close the drive until a check is heard.check device manager to ensure device is listed and then go to its 'properties' ensure the current devis is recognized.you could also do a remove device,reboot, and have OS recognize a new device.clean the device with a lens cleaner.
Jun 22, 2008 | Toshiba Satellite A105 Notebook
Toshiba problem
On boot go into your BIOS and set your CD/DVD ROM drive to first in the boot order options, then with the CD/DVD in the drive reboot your computer and wait for a prompt to "Press any key to boot to this CD" and do so (you'll only have a couple of seconds so be ready or reboot again) and you then will be taken through the loading of files until you get to your partition/install screen options, where you'll delete the partition that your OS is on, then create a new one and then format that partition and install XP on it.
May 07, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S4004 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
