This is your standard front panel configuration. the wires from the case should have different colors for positive and negative. the colored wired is usually positive and the white typically negative. please refer to case manual for clarification. you can also test to make sure this is where the power switch location is by "jumping it" with a flat head screw driver. i would do this to verify the location first. again this is simply the standard configuration and i can't guarantee that your board is set up this way.
hope this was helpful.
