Question about Sony STR-DE875 Receiver
I want STR-DE875 REMOTE CONTROL (sandal colour)
Posted by Balaji Sridharan on
Dick Johnson
    New Friend:
    Problem Solver:
  • 3 Answers
There is one one Ebay. Search for RM-PP505
Posted on Dec 09, 2009
Remote work properly
Make sure the batterys are good if so open the remote and check the led that send the signal it may be unsoldered
Oct 26, 2013 | Sony STR-DE875 Receiver
Problem with SONY STR-DA555ES home stereo receiver popping & going into protector mode
You may have the speakers incorrectly connected or the speakers you are using have an impedence that is too low for the amp to support.
Sep 15, 2013 | Sony STR-DE875 Receiver
Str-de875. Remote is suddenly not making the amp work. the remote still turns tv on/off
does the light blink more than once when you select the 'contol the reciever now' button? I assume you push a button to switch which device the remote will control, and then push another button to astually have the device do something
Mar 09, 2013 | Sony STR-DE875 Receiver
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Aug 23, 2010 | Sony STR-DE875 Receiver
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
How to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
Mar 10, 2008 | Televison & Video
Remote Doesn't control stero
Blinking doesnt always mean that the IR transmitter is working in the remote.
Check a couple-few of the online remote dealers you may be able to get one cheap.
Feb 24, 2008 | Sony STR-DE875 Receiver
Sound turns off for Sony STR-DE875 amp
If you do not here a click as soon as the power is turned on, (note you must be in a very quite environment no noise absolutely to hear this) then the amplifier has blown output transistors which are pushing DC current to the speakers.
Aug 31, 2007 | Sony STR-DE875 Receiver
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
Sony STR-DE875 Receiver Logo
Top Sony Audio Players & Recorders Experts
aliasger yq
Alvin Barnabas
Alvin Barnabas
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
