T-Mobile Sidekick II Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i get a replacement lcd screen - T-Mobile Sidekick II
Ervin Banks
Level 2:
  • Expert 107 Answers
  • Posted on Dec 09, 2009
Ervin Banks
Expert
Level 2:
Answers
107
Questions
0
Helped
25762
Points
354
Go to your mobile company store and they should fix it for you for a price, or you could just buy a new phone all together.
Hp g5000 sreen does not light up as usal, i can see a the start up when i shine a torch at the sreen, what do i need to do to get working.
An LCD screen cannot produce enough light by itself. It needs an additional source of light.
A Backlight is used as the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to the Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
The LCD screen is a composite of layers, surrounded by a thin metal frame that resembles a picture frame.
To one side of the LCD screen layers, and under the frame is usually where the Backlight is mounted.
[Note* Two Backlights are used in some models]
Replacing a Backlight is more labor intensive than replacing an Inverter.
Due to this, and the cost, the LCD screen itself is replaced as a unit most of the time, when it comes to Backlight replacement.
Example of a replacement LCD screen for the HP G5000 series of Notebook PC's,
https://www.screentekinc.com/HP_G5000_Series--15.4-inch--1280x800-wxga-laptop-lcd-screen.shtml
[Note* Stating HP G5000 is just stating the model series. When buying replacement parts the EXACT Model Number should be used. This information is located on the bottom of the laptop, in a white Service Tag.
When replacing an LCD screen, the model number of the replacement LCD screen should be matched to the existing LCD screen's Model Number.
Inverters and LCD screens are matched together. Make sure you get the correct part]
An Inverter is used to provide power from the laptop to the LCD screen, and to the Backlight.
Note* 90 Percent of the time the problem is a bad Inverter.
Example of an Inverter for an HP G5000 series notebook PC,
http://www.zlectronic.com/product/INVERTER-FOR-HP-DAC-07B035-DAC-09B017-DV5000-G5000.html
The LCD screen, Top Cover, Display Bezel, Inverter, Backlight, and various screws, make up the Display Assembly.
The Display Bezel made of plastic surrounding the LCD screen, and in front of the LCD screen is removable.
Behind it is easy access to the Inverter.
The Inverter is approximately 4 inches long, and the width of a No.1 pencil.
Usually located at the bottom of the LCD screen, and right behind the Bezel.
This article shows replacing an Inverter and LCD screen on a Compaq Presario v2000 series Notebook PC,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-compaq-presario-v2000-laptop/
This pictorial guide is not for the HP G5000 series Notebook PC, but the models are very similar when it comes to Inverter replacement.
The above link is to show you what is involved.
Please post questions in a Comment.
Regards,
joecoolvette
2answers
Lcd light
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD screen is very easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
I need a whole new screen or swivel screen! any help?
You can try to reseat the lcd2.gif cable and make sure it is tight. It that fails then you will need to replace the LCD screen
Here are instructions for replacing the Sidekick2.gif LX screen: How to replace the Sidekick LX LCD Screen
and here is a link to the LCD screen son ebay.
Sidekick LX LCD Screens
2helpful
2answers
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
1helpful
2answers
I have an lg shine phone which i dropped. I turned it on and found the screen had been damaged. You could only see part of the screen and the rest was faulted what shall i do?
thinkpink248
I agree with the second option. A LCD Screen on Ebay is only about $20. And it is simple to replace yourself. Here are 2 links that would benefit you. The first is a repair guide for how to replace the screen. The second is a good link for where to buy Replacement LCD Screens.
Replacement Guide for Broken LG Shine LCD Screen
Cheap replacement LCD Screens for the LG Shine
Question??
It is easier to replace the whole lcd flip screen. It is only 2 screws and it is about 10 dollars more.
See these 2 procedures for the difference.
replacement of the Sidekick 3 LCD flip screen.
Sidekick 3 LCD Screen Only Replacement
Top T-Mobile Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
