Question about Yamaha Televison & Video
Codes to program a yamaha remote rav283 - Yamaha Televison & Video
Posted by mrtnphl on
Anonymous
    New Friend:
This remote was sold with the HTR-6130 reeciver(among others.) The HTR-6130 manual contains instructions and programming codes. You can download the manual here: http://static.highspeedbackbone.net/pdf/Yamaha-HTR-6130BL-Manual.pdf
Posted on Dec 04, 2010
Ryan
My rav283 will not work with my apex television. The codes won't work. Suggestions?
Posted on Oct 07, 2012
1 Related Answer
Anonymous
SOURCE: looking for rav283 remote control: yamaha
HI I HAVE THIS REMOTE CONTROL RAV 283
Posted on Nov 16, 2009
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
My Yamaha RAV283 all of a sudden will not turn on or off my T.V.; input button will not respond but still controls volume?
if you are confident enough to take the unit apart you can remove the rubber button pad and clean the surface of the circuit board
with q tips and reassemble the unit. They get dirty over time.
Most units have screws at the bottom back or in the battery compartment. Be careful not to tear the rubber contacts(pad)
Oct 01, 2014 | Yamaha Remote Control RAV283 p/n:WN058100
Is it possible to program an alternate remote to replace the Yamaha GX-50 OEM remote VU506200.
You could pick up a new one at this website for $40. Not sure if that is feasible.
YAMAHA GX 50 AUDIO REMOTE CONTROL SYS1 VU506200
I believe the ZA11360 remote works with Amplifiers and is not compatible with the GX-50 mini sound systems. You could try and buy a universal remote and then try and program it for the GX-50 but it is hard to find codes. There are a few Yamaha sound system codes available on the web and you could try these with the ZA11360. But these are for Yamaha CD players. Try one of 60036, 60490,61907.
Aug 03, 2014 | Yamaha Remote Control VU506200...
Hi how are you i have the yamaha universal RAV283 I would like the code to set my magnavox tv please help me thank you
Hi their, i found these codes.
Magnavox 0060, 0061, 0063,
0102, 0103, 0150
give them a try and let me know if it works : )
Feb 06, 2011 | Yamaha Televison & Video
How do i program for sony cd player
I also have a Sony CD player (CDP-XE330) and I have tried almost every code from the yamaha manual, but without success.
The only codes that yamaha remote supports, are the codes from the list in the yamaha manual. If none works, you are out of luck and the only solution is using the original sony remote (if you have one) or universal remote.
I have recently purchased Logitech Harmony 525 on eBay and now I control all my 7 devices with it without any issues. It is programmed via USB and Logitech has codes for almost 250.000 devices.
Sep 16, 2009 | Yamaha RX-V361 Home Theater Receiver
Scientific Atlanta 8300hdc remote program instructions
Don't know the exact code for your STB, but you can download the manual from http://www.yamaha.com/yec/products/productdetail.html?CNTID=5027893&CTID=5000300&RLTID=1505&DETYP=RELATION ,
There you can find the list of all codes and also how to program them into the remote.
Apr 09, 2009 | Yamakawa DVD-218 DVD Player
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Remote code needed
20839 is the DirecTV & Access HD universal remote code for Mintek, Shinsonic, & US Logic. None of which brands are listed in my Yamaha RAV283 remote code list (uses 4-digit codes).
20717 is also listed for Mintek by DirecTV. Other brands with the same code on DirecTV remote are: Apex, Blaupunkt, GE, Greenhill, Initial, KLH, Nesa, & RCA.
Of those brands, only Apex & RCA are listed in my Yamaha remote's list. I tried all of the codes for those 2 brands under types DVD, DVD Recorder, DVD/VCR, & TV/DVD. None worked. It appears to me that only those 3 brands for 20839 share the same remote code settings. If your remote doesn't support any of those 3, I doubt you will be able to use that particular remote with the Mintek DVD-1600.
I hope my research helps someone with this, as it was unfruitful for myself. Good Luck!
Jun 15, 2008 | Mintek DVD-1600 DVD Player
Televison & Video Logo
10,436 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
