Microwave Ovens Logo
Question about Microwave Ovens
How do you reset the clock on the microwave
Posted by supertroo662 on
Anonymous
  • 1,305 Answers
I'm not sure of your microwave model, but try this:
Press CLEAR
Press CLOCK
(if the display scrolls instructions, follow them...otherwise continue )
Enter the hour and minutes
Press CLOCK again.
If the display shows current time...you're done..
If not, try Clear, Clock, and START.
One of these should get your clock set.
Posted on Dec 09, 2009
Anonymous
  • 11,896 Answers
Press clear, press clock, enter time, press clock again.
After each use, microwave clock disappears and microwave will not work until clock is reset. The clock will not allow itself to be reset unless we reset the circuit break which was not tripped.
Sounds to me like a fault with the main circuit board. Lets say the microprocessor on the board is bad and it locks up or just doesnt display the clock or time. When you reset the breaker you are resetting the main board. and it works until the processor fails again. Sound like may need new main PC board. Timer board. Caution!! Pricey??? Check cost of board before persuing, may be more wise to replace unit. and get new full warranty
Reset clock on over the range microwave
Go to this link....you can download the users manual. The procedures for setting the clock are on page 22 of 68.
JVM1950SR1SS GE MICROWAVE Manual
2helpful
How do I set Clock?
Disconnect the microwave from the power source while the power is still out. If the microwave is a built-in, turn off the circuit breaker. Otherwise, unplug the microwave from the wall outlet. This prevents a power surge from damaging the magnetron tube when the power is restored.Turn on the circuit breaker or plug the microwave into the outlet only when you are sure that the power is permanently restored. If there are still storms in the area, the power may be disrupted again. Reset the clock on the microwave. Microwaves vary slightly on how to set the clock, but usually there is a clock button you press. Use the number pad to input the correct time and press the clock button again to set it. Test the microwave by heating some water to ensure that it is still in good operating condition.
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
3helpful
Whirpool microwave resetting clock
Whirlpool Microwave X2-30ES
I was pressing one too many buttons.
Press Clock, then Stop, press in the 24 hour time digits, then press Clock again.
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
3helpful
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
HOW DO I RESET MY GE JE1549GW MICROWAVE
Terry I am assumming that you are referring to resetting the clock. If so, push the clock button then set the time then push the clock button a second time and you should be all set.
Shuts off after maximum of 8 seconds. does heat when on.
Sounds like the controller board has failed, assuming a circuit breaker has not tripped or fuse has not blown.
If all you do is reset the clock, and then it looses time, regardless of using the microwave, then it points to the clock/controller board.
If this only happens when you use the microwave portion for a few seconds, I would be suspicious of the microwave circuit, where there are several components that could cause the failure.
Top Microwave Ovens Experts
Marvin
Marvin
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
