Aiwa CDC-X304 CD Player Logo
Question about Aiwa CDC-X304 CD Player
Buttons stopped working
I got this head unit from my sister. she has taken good care of it. i installed it in my eagle talon, worked perfectly and sounds great. ho ever about 8 months after, a couple of the buttons stopped working, then all of the buttons within 1 weeks period. the only button that works is the cd eject, other than that theres no volume, next, back, change source or any other button. still works and plays. have tried the reset button, and at one point didnt have battery hooked up to it for 6 months. im pretty good at fixing things but i dont want to mess it up if theres a solution. doesnt seem like theres much i can do though. if i dont get help or if i get a new cd player in my car, ill open it up and see if theres a blone solder point or disconnected wire and will post it.
Posted by amyxagl on
kenw392
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Aiwa Master
  • 2,226 Answers
Sounds like you may have a bad switch. if you have a multimeter you can check to see if a switch is reading less then a few megaohms. if one is reading a few kilo ohms, it is probably bad.
Posted on Dec 09, 2009
  • alex Oct 02, 2013
    I got Sony Cdx-GT340 after 3 years my buttons stopped working, the reset button didn't work, other suggestion was to use cotton swab with little alcohol to clean contact, at first I cleaned but it still wouldn't work, so having nothing to lose, I really saturated swab and freely used it on male connector and quickly shoved it into female connector -- and voila!!! it start working!!!!!!!
alex
    New Friend:
Posted on Oct 02, 2013
Having a problem with my 1994 eagle talon. no
shake at idle means u have a cylinder misfire or low commpression, here are causes of misfires most commonly seen.
The most common misfire causes on the cars I've worked on have been:
  1. Spark plugs
  2. Spark plug wires
  3. Ignition coil
  4. Fuel injector
  5. Wiring to fuel injector
  6. Timing Belt
  7. Vacuum leak or stuck open EGR
  8. Contaminated fuel or bad fuel pump
  9. Weak compression
  10. Blown head gasket
'98 Eagle Talon squealing, smoking, AC not working
check and see if the head gaskets are blowed you may have a cracked or blown head or head gasket
Replaced head gasket on 91 eagle talon turbo
clean out the plug ins with electrical cleaner...sounds like something isnt plugged in or got cut or grounded out when u took all that stuff apart
1997 Eagle Talon AC button switch blinks AC won't work
If the button is blinking, this means the clutch is either worn out, or the clutch is not engaging because of an electrical problem. Check the electrical connection going to the AC, does it look alright? Is there any fluid inside the connector? I would replace the AC compressor if the clutch persists to not engage.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
95 Eagle talon tsi FWD won't go into 5th
Most likely your synchros or too much grind and find. Just do a good ol' fasion rebuild and take care of any other potential problems that could pop up in the future. Good luck
1991 eagle talon speedometer not working
Possibly bad vehicle speed sensor causing problem
1994 eagle talon is not starting up!
i would check the coil or, distributor unit and wires then, i would also check the battery for weakness. if the batt is fine, check the starter and wires that lead to the starter as well. sometimes the starter wires can jiggle themselves loss at times. hope that helps ya and thx for using fixya:)
My 1992 Eagle Talon TSi
it is low oil pressure. Mine did the same thing until I switched to 10-w40 motor oil. the thicker oil makes up for the wear in the oil pump. If that doesn.t work, then probably bad pump or main bearing. The main bearing helps regulate oil pressure too
2answers
Broken timing belt on 91 eagle talon
if you have the 1.8L engine, you can just replace the belt and you'll be fine.
if its the 2.0L(turbo or non-turbo) , you will have bent valves.
the head needs to be pulled and the valves replaced.
Top Aiwa Car Audio & Video Experts
AAA TV Service
AAA TV Service
ADMIN Andrew
ADMIN Andrew
Marvin
Marvin
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
