Question about Dell Dimension 4600 PC Desktop
I have just installed speakers on my computer, but I can't get any sound.
Posted by cjburb56 on
Melvin Ramos
    President:
  • 2,923 Answers
If you are running Windows XP or Vista, first check the volume properties and next the sound properties.
1. Locate the speaker icon on your Tool bar and click it. Make sure that the volume is set to mid-range or maximum. Be sure that the mute box is not checked.
2. Go to the Control Panel and click on "Sounds" (for Vista) or "Sounds and Audio Devices" (in XP).
3. Go to the "Audio" tab and make sure that the brand of your sound card is selected under the Sound playback and recording.
If same problem occurs, try connecting your speaker into another computer to see if the problem is the speaker.
Thank you!
Posted on Dec 09, 2009
jdthefixer
  • 747 Answers
Check to make sure the speakers power up.
Check to make sure you have installed the speakers into the correct jack on the back of the PC.
Go into Control Panel and check the settings by double-clicking the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and that the volume is turned up.
1helpful
2answers
I dont have any sound, I got a message bottom right corner when I click on speaker icon "No Audio Output Device is installed" I think I need drivers for X-220 speakers, I can't find them...
You don't need a driver for the speakers, but a driver for the sound card installed inside your computer. If the computer came with that sound card then you can find the proper driver from the manyfacturer website -> Support section.
Sound drivers need to be reinstalled sometimes after iTunes updates or video game installs.
2answers
I do not have the software on my computer to install the speakers. where do i find it online?
No software is required for (any) speakers!
Just connect the speakers to the outlet and to the GREEN jack on the sound card...
If no sound is heard, make sure the sound card driver is properly installed and the sound is not muted.
Regards,
Pelu.
No sound from speakers
I hope you have plugged the devices correctly. It might be a problem that you have not installed the sound drivers, install the sound drivers correctly and check. If after that you are not getting the sound check your speakers in another computer to verify that the speakers are working properly. It can also be a problem of your sound card, it might not be working properly.
Speakers not detected ..
first u check sound driver are matching motherboard
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
After replacing the harddrive in my computer, my speakers no longer work. Under Control Panel, Sound, I get mesaage "no sound deice installed" In device manager, I have several sound devices installed all...
You need to unplug speakers if plugged in. Install the software and drivers for your Speakers. Then plug them in and you should be able to use them. If this doesn't work, go to device manager remove all USB devices, and reboot, then re-install software & driver. Then plug in ya speakers. They should work.
Acer m1118b speakers
There is no software for speaker , first off all u should check the sound driver of ur computer if it is install but no sound coming out plz uninstall the driver from ur computer then restart , after restarting ur computer then install the driver properly then check the cbale of ur speaker whether it is properly connected to the right port of the computer
2answers
Sound
did u install sound card drivers
if u install correctly go to control panel and sound
check there whether audio device is showing or not. if not u didnt install ur audio otherwise u installed correctly but the problem is in ur speaker.
Speakers
  1. first findout the problem is due to speaker or from your computer soun driver or hardware.
  2. for checking speaker, connect to an ipod or walkman to the speaker input if it works the speaker is okay
  3. check the computer sound driver software may installed properly
  4. for these type dxdiag on run in the start menu
  5. check the sound driver problem, if it re install the sound driver by using its cd
Dell Dimension 4600 PC Desktop Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
