We have a 60" LG Plasma. We can here the channel but the screen is completely green. Any thoughts on the problem / solution??
First thing to do would be to check your cables feeding into the TV. If you're using component cables, it's likely that your red and blue cables have come unplugged and all you're feeding to the TV is the green signal. However, if you're using a different set of cables or they're all plugged in properly, I would first suggest swapping out the cable for a new one. In newer televisions, such as yours, each of the colours is transferred through separate channels regardless of the type of cable used.
If either of those don't help then I'm afraid you've got an issue with the charging of the phosphorus gas itself, either it's not receiving the power correctly or some of the gases are remaining inert and not charging. If you're at that stage, you need to seek technical assistance from a service depot or LG.
Best of luck!
