Question about Brother XL-5340 Mechanical Sewing Machine
I have lost my manual to my Brother XL 5340. I want to use the button holer but dont' remember how and am not even sure that I'm attempting to use the right foot.
Posted by cruiserjake on
Anonymous
    New Friend:
I just downloaded the entire manual for my Brother XL 5340.
http://www.retrevo.com/support/Brother-XL-5340-manual/id/19095dj796/t/2/
Posted on Dec 11, 2009
  • Anonymous Dec 11, 2009
    the manual is 44 pages. so I saved it on my computer in Adobe format. (the web address is the one in blue...www.retrevo.com....etc.)
Motor locked up and there isn't any tangled thread anywhere in the machine. Pressed the OK button and it still is jammed
try unthreading completely and make sure that the bobbin casing allows thread to come up when you rethread the machine. Make sure that you are turning the handwheel towards you not clockwise, because you can mess up the timing. Read the manual for other suggestions.
Sep 08, 2010 | Brother XL-5340 Mechanical Sewing Machine
The needle on my brother XL 5340 sewing machine does not appear to go down far enough to catch the lower thread.
Hi. Check to make sure that the flat side of the needle shank is facing to the rear (away from you), that the needle isn't bent, and that it is inserted as far up as it will go.
Hope this helps,
Robbie
Aug 16, 2010 | Brother XL-5340 Mechanical Sewing Machine
Does the Brother XL-5340 do an overlock stitch? If it does do I need to change the foot and to which foot? Thanks
There is an overedge stitch (page 38) that uses the regular presser foot.
If you do not have a manual, you can download (free) from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5340
Mar 31, 2010 | Brother XL-5340 Mechanical Sewing Machine
Machine not sewing
Have you checked that the tiny screw in the bobbin is not loose, sometimes this creates this problem for me or if the bobbin size is incorrect.
Dec 13, 2008 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother xl-5340
You can download the manual from the link below: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000062/xl513052325340ug01enesfr.pdf It has diagrams of how to thread the machine. There is also a FAQ section: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_xl5130eus.html?reg=us&c=us&lang=en&prod=hf_xl5130eus Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 Mechanical Sewing Machine Logo
260 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
