Question about Kodak EASYSHARE G610 Thermal Printer
Replaced ink cartridge turned dial get pink and yellow pictures cleaned sensor same thing
Posted by tomkryger on
Eseoghene Daniel Williams
  • 428 Answers
A lot of times you need to do more than clean sensors to get results. You are getting yellow and pink because either soe colours (blue & black) are dried at the nuzzle or finished.
The procedure am giving you below will determine which is the case.
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Posted on Dec 08, 2009
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
When I print out picture, pictur came out so many pink stripe across the picture.
There probably is nothing wrong with your PINK ink-cartridge.
It's one (or two) of the other colour ink-cartridges that either are EMPTY or having CLOGGED ink-jet mechanisms.
Run a "print-head-cleaning" cycle.
Aug 27, 2010 | Epson Stylus 1400 InkJet Photo Printer
My hp 712c printer prints only the pink band when I run a color test. I have replaced the original cartridge. Any ideas about the cause and solution.
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
Jun 24, 2010 | HP DeskJet 712c InkJet Printer
Canon IP4500 Printer yellow colour will not work even after deep cleaning many times, Pictures come out with pink tone
I replaced the cartridge but not fixed, so I washed the Cartridge holder in warm water still no good, I then soaked the Cartridge ink holder in metholated spirits for two hours and then washed with warm water dried it off and now it works perfectly.
Jun 04, 2010 | Canon Pixma iP4500 InkJet Printer
New kodak esp5250
Try to clean the printhead
Press Home > Maintenance > Clean printhead
If still the same issue
Visit www.kodak.com/go/itg
IF still same issue call or chat with tech support and get the printhead replaced free of charge
Jan 03, 2010 | Kodak ESP 5 Printer
My printer is not printing anything orange, it comes out pink. Just put in new cartridges.
It sounds like your yellow is not printing correctly (probably a clogged nozzle). If your printer has separate cartridges, replace the yellow. If you are using aftermarket cartridges, you should try using OEM cartridges since they are spec'd to the printer. If you are usng aftermarket or reloaded cartridges, the ink may not be up to specs. In any case the yellow ink cartridge needs to be replaced. Make sure to run a deep cleaning and alignment after replacing the cartridge.
Sep 11, 2009 | HP Computers & Internet
Replacing Blue Ink cartridge
The nozzle check takes very little ink it sounds as though you need to do a head clen though.
Aug 01, 2009 | Epson Office Equipment & Supplies
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
Kodak EASYSHARE G610 Thermal Printer Logo
100 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
