Question about Sewing Machines
I suspected the magnetron is weak or failing. I ordered a new magnetron from sears. They sent me a whirlpool P/N 2M261-M22. Is this the correct magnetron for my microwave? Also where is the magnetron located in my microwave?
Posted by daventonia2 on
  • daventonia2 Dec 08, 2009
    Is my assumption that the magnetron is failing a good assumption. The symptoms are that it takes a lot longer to defrost, reheat, and cook food items.
  • daventonia2 Dec 09, 2009
    thank you, I feel that your advice is technicaly excellent. David Swarner
Anonymous
  • 647 Answers
I don't see the model # of your microwave listed here but if you have the new magnetron in hand than you know what to look for.
A word of Caution regarding the Magnetron and Microwave HV Capacitor - The HV capacitor must be discharged before working on the magnetron - the capacitor holds a potentialy lethal charge even when the set is unplugged.
The Magnatron is located usually on the right hand side, upper, center of the microwave. Once the back cover is removed it will be easy to identify by comparing wth the new one - the top part will not be exposed and there will be a two HV (high voltage) wires (usually red) connected to it and four screws or bolts holding it in place. The part # is on the old one and you can compare this to your part #. The part # you mention is common and crossreferenceable to a few other magnetrons.
The HV capacitor is a oblonged shped cylinder can with a component (diode) across its terminals - to discharge be sure the set is unplugged and short the terminals to chassis ground.
Reply to this post if you have further questions.
Posted on Dec 08, 2009
  • Anonymous Dec 08, 2009
    The assumption that the magnetron is bad because it dosn't heat as well as before is not necessarily true but is possible.
    The magnetron operates either full on or not on (off) it dosn't generally deteriorate with time.
    The problem could be the stirer fan is not distributing the heat evenly or there is arching occuring at some internal point that robs energy from the heating process.
    It could also be that the magnatron is cutting in and out of operation and therefore not giving you full power continuosly.
    High medium and low temperature of a microwave heating is not a function of the power fed to the magnetron but a function of how often the magnetron receives it's preset full power on.
    In other words the power is not varied but the amount of time is varied.
    Check this by heating the same amount of water for the same amount of time (on high setting) and checking for consistent heating - it should always be the same.
  • Anonymous Dec 09, 2009
    Your welcome and thanks for the feedback.
I would like to order an owners manuel for a Singer Inspiration model#4220 thank you
well you search --singer operators manual for inspiration model 4220 -- and then down load the pdf version
fixya site doesn't take orders
Aug 03, 2018 | Singer Sewing Machines
My foot pedal is sticking on my 750D overlocker. How can I repair it or do I have to buy a new one. If I do where do I get it.
sadly neglected to give us the name brand and model number there is a spring tensioner that is used to lift the pedal after you press it down it may be worn out or broken you could order a new one or try to fix yours I sent you a link ordering a new one below Amazon com Foot Controller And Power Cord 033770217 Sewing Machine Foot...
Mar 27, 2018 | Sewing Machines
Amazon order was undeliverable. Where is item? How to get it delivered? Can I cancel it and later reorder to new address?
About Undeliverable Packages
Occasionally packages are returned to us as undeliverable. When the carrier returns an undeliverable package to us, you will be issued a full refund (including shipping charges).
Orders that are returned to us as undeliverable are not able to be re-shipped. If you would still like to purchase items that were undeliverable, you are welcome to place a new order on our website.
If it has been four weeks from the estimated delivery date and you haven't received confirmation of the return or refund, please contact us.
Jan 14, 2016 | Brother CS6000i Computerized Sewing...
I can figure out how to install a new tension dial that I ordered. When I install the part (as it came) it will not work. There is an extra ring that came with it but there are no instructions with t
This is why you let the professional do the repair correctly and safely. Please take it in for service and adjustment for happy sewing times.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 03, 2014 | Sewing Machines
I need the screw for my presser foot lever on my Sears Kenmore sewing machine, model 158.17600-pretty sure the part is 31027. If I don't have this part I can't get the presser foot to lower, correct? Or is...
I would go online to Sears parts direct (google it) and order that part. Or, if you have a sewing machine repair shop near you, I bet that they can set you up pretty reasonably inexpensive. Good luck
Nov 10, 2010 | Sewing Machines
I have a Singer Esteem II Sewing Machine model 2273. I ordered the ruffler foot 086742-P as listed on the website. I can get it to fit on the machine...i think...however when i lower the needle it hits...
Are there other needle positions on your machine that will allow the needle to pass without hitting? Otherwise, I suspect the accessory you have is not installed correctly or is not correct for your machine.
Jan 14, 2018 | Singer Sewing Machines
Washing machine
Please find the requested website mentioned bellow:
http://www.sears.com/
Thats what you were looking for:
God bless.
Jul 08, 2009 | Kenmore 15343
R/W soft pc-link 19000 will not load
I have Ver. 1.1 and also have Vista. I have called Sears, been transferred over and over, called Kenmore again transferred and then sent back to Sears. I have searched online and can't find anything! I really want to use my machine but without the software it makes it so limiting. HELP! Anyone out there know what to do???
Dec 29, 2008 | Kenmore 19001
Kenmore Sewing Machine
E1 error on Kenmore sewing machine model 385.19233
Jul 20, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
