Question about Robitussin Cool Moisture 1 Gal. Humidifier
HOW TO REPLACE FILTER #wf813 - Robitussin Cool Moisture 1 Gal. Humidifier
    New Friend:
It's easy to find a replacement if you know what the model number is of the humidifier. If you do, let me know.
Posted on Jan 15, 2010
Anonymous
SOURCE:
What does the ceramic cartridge in the powerpure 3000 humidifier do and When do you need to replace.
PowerPure 3000 Ultrasonic Humidifier
This review says it has a permanent ceramic filter that cleans the water in your tank. Another review said the ceramic filter softens and cleans the water.
Amazon com PowerPure 3000 Humidifier Home Kitchen
That model appears to not require replacing the permanent ceramic filter. Other models have filters that need to be replaced.
Jan 27, 2018 | Humidifiers
Is there a filter I need to replace in the Walgreens humidifier model # 2055? Tks
Most humidifier's have a filter I would google make and model along with filter replacement you should be able to pick up a on line manual to get correct size and how to change it .
Jan 03, 2018 | Walgreens Humidifiers
I have an essick humidifier and it keeps flashing CF but it continues to run. What does the CF mean.
Check Filter Indicator The ability of any humidifier to efficiently supply humidity output relies heavily on the condition of the filter. As the filter loads with impurities it gradually loses its wicking capability. When this happens, moisture output is reduced and the humidifier has to work longer to satisfy the selected setting. This humidifier has a check filter reminder timed to appear after 720 hours of operation. When the Check Filter (CF) message is displayed, disconnect the power cord and check the condition of the filter. If a build-up of deposits or severe discoloration is evident replace the filter to restore maximum efficiency. The CF message is reset when the humidifier is plugged back in.
Dec 03, 2017 | Humidifiers
Package indicates wilter might need to be chaged once a season
You should probably follow the directions in the instruction manual, which do say how often to change it. If you wish to risk a moldy house or an unproductive filter you can use it longer than advised. I soak mine in 50% vineger 50% water for an hour to dissolve mineral deposits and kill fungus, so the wick doesn't become too clogged to operate. I believe this lets it last a few times longer, but it is a Honeywell model of filter and I don't know how that would work on your filter.
Mar 06, 2014 | MoistAIR Genuine MAF-1 Wick Filter
CF is displayed on my humidifier...what is that?
Mar 05, 2011 | Bemis 826 800 Humidifier
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
Nov 19, 2010 | Sunbeam (0013871361) Humidifier
Moldy smell
Replace humidifier media pad (filter) with a new one, and clean interior of humidifier housing with a solution of warm water and vinegar, also replace or clean furnace filter, Good luck.
Mar 02, 2010 | Humidifiers
Replacement filter
You can buy them on amazon.com
http://www.amazon.com/WF2530-Bionaire-Humidifier-Replacement-Filter/dp/B0009H79HG
Or is you just google bionaire ws3560 filters and you will find lots of places on the net to buy them.
Good Luck
Feb 06, 2008 | Humidifiers
Carrier Humidifier MN# HUMCCLFP1218A - not working
First of all the white build up is hard water residue. If you haven't replaced the filter in 3 and a half years you NEED to replace it. They have a safety switch may not be satisfied because of your filter.
Dec 21, 2007 | Humidifiers
Robitussin Cool Moisture 1 Gal. Humidifier Logo
227 people viewed this question
Top Robitussin Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Robitussin Humidifier Expert? Answer questions, earn points and help others
