Question about Toshiba Satellite M105-S3004 Notebook
I would like to reset the bios password on a Toshiba Satellite M105-S3004
Posted by bpmurphy66 on
Jack Bilsby
    New Friend:
I have the same problem, have u fixed your laptop yet? Please tell me what you did/tried.
thnx
Posted on Jan 06, 2012
Anonymous
How to reset bios? my pc destop is acer aspire m1641
Posted on Dec 15, 2009
Anonymous
    Brigadier General:
  • 10,406 Answers
Find your original sales-receipt, and telephone Toshiba,
to show that you have proof-of-ownership.
You cannot "reset" the password -- nor can a thief who has stolen your laptop -- this is for your own protection.
Posted on Dec 08, 2009
My Toshiba Satellite Laptop M105-s3004 Crash and fan not running
Because the fan doesn't work, your laptop is overheating and going into thermal shutdown. have the fan replaced and the area where it is screwed to cleaned as it harbours dust over time preventing adequate cooling.
Jan 25, 2010 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M105-S3041 clock problem
Chances are your CMOS battery is dead, it can be replaced inexpensively if you do it yourself. After taking the laptop apart, locate the battery, it looks like a large watch battery. When you remove it, note the battery type and run to your nearest battery store for a replacement.
Jul 07, 2009 | Toshiba Satellite M105-S3004 Notebook
Bad motherboard
yes they should be just look up the specs on toshibas web site to make sure it will accept your processor.
Jan 16, 2009 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M105-S3004 says no operating system found. tried to insert restore disc but it runs for about 20 seconds then turns off.
it sounds like your HDD has suffered a critical error. Go here and download this torrent. This will need to be burned to a disk. now it comes with FreeDos installed. Put the disk in the drive and bootup. use option 5 to repair your HDD. after this finishes try booting your system up.
Jul 17, 2008 | Toshiba Satellite M105-S3004 Notebook
Bios password reset
from the Toshiba support site
The BIOS and Supervisor passwords cannot be removed or changed unless you know the existing password(s). If you forget your BIOS or Supervisor password, you will have to have the password removed by a Toshiba Authorized Service Provider. Although the prompts for these two passwords have the same appearance, the passwords are set and removed differently. If both are set, the Supervisor password takes precedence.
I assume that the notebook will have a BIOS battery similar to a standard PC. If you are happy to disassembe it you may be able to reset the BIOS by removing the battery and/or locating the bios reset jumper
Another alternative is to If this doesn't work or you dont want to disassemble the PC, you can try to build the Toshiba Parallell loopback.
A lot of Toshiba computers remove the password when you boot it up with the loopback connected
It can be made out of a 25pin male connectors (db25). Connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25
Jul 12, 2008 | Toshiba Satellite M105-S3004 Notebook
Toshiba m105 s3004 bios password
i have a Toshiba satellite M105-S322 and all i had to do is open the ram compartment and pull up the plastic sticker or whatever you want to call it between the motherboard and the ram. There is a jumper called "CMOS_CLR1" use a screwdriver to short out the pins and it clears the CMOS.
Aug 24, 2007 | Toshiba Computers & Internet
Laptop fingerprint reader
http://www.newfreedownloads.com/find/fingerprint.html
Jun 26, 2007 | Toshiba Satellite M105-S3004 Notebook
Password needed
Hello nic208, The problem is you have a BIOS level password installed. Laptop owners and computer departments sometimes install them in case the laptop is lost or stolen to prevent unauthorized users from gaining access.
Jan 06, 2007 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M105-S3004 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
