Question about RCA Televison & Video
Popping and cracking noise from rt side speaker
My RCA TV, D52W17, has less than 100 hrs on it. When I turned it on yesterday it made a popping and cracking noise from the rt side speaker. I unplugged the rt speaker and the noise quit. I swapped the speakers and the noise stayed on the rt side. Any thoughts? Thank You!
Posted by fdr001946 on
Paul Bade
  • RCA Master
  • 1,666 Answers
You probably have a bad solder connection or an intermittent part failure in the right audio amplifier or its source circuitry. Put in a call for warranty service.
Posted on Dec 08, 2009
RCA DVD Home Theater System popping noise now wont turn on
if no any power indicator the first place to be check is the power supply where in the fuse get blow. if the fuse blown with darkened color that was mean has shortened line, might the amplifier circuit get damaged that cause of popping before it totally down.check for bad amplifier ic and shorted diodes.
Jul 26, 2012 | RCA Rtd315w Dvd Home Theater System...
Our RCA HD62W59 makes a loud squealing noise after being turned on for about 10-15 minutes.
I had the same problem on my hd52w59 hdtv and sucessfully fixed it yesterday from an answer i found here...so hopefully im paying it forward.
First off, im no TV tech so you do this at your own risk!!! Based on the research ive done regarding this subject, if there is no issue with the picture and its not related to speakers(ie. if you mute it and it still makes the sound) then its the horizontal drive coil. The fix i read was to put nail polish or hot glue around the coil. Well i came up with something easier and its worked for a few days now(fingers crossed). An old fashioned wooden clothes pin. Put it on the horizontal drive coil and it absorbs the harmonic frequency(high pitch noise). I realize this is a wooden object on a electrical piece that heats up but i have had no issue as of yet.
Now, how to locate the noisy horizontal drive coil...unplug TV from power, remove the lower rear panel around where the wires go into the tv. There are about 8 #20 torx bit screws you remove, then use a flathead screwdriver to pop one clip on each side and 3 underneath, this will allow the plastic trim panel to pop off. Get a flashlight aimed in there so you can see the components. Plug the TV back in and turn it on...wait for the noise. Now make sure you dont touch anything high voltage and once again you do this at your own risk...but take a small wooden stick (i used the stick from a plunger) and touch it to the suspected culprit...when you touch the noisy drive coil the noise will immediately go away. Once you know which one it is turn the TV off, unplug it, and put a wooden clothes pin on it. Plug the TV back up, turn it on and ensure the sound doesnt come back before putting everything back together.
Beats the hell outta paying a technician $75-100 plus parts, huh?
Jan 26, 2011 | RCA HD52W59 HDTV Projection Television
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
When i turn on the tv 52" rca rear projection the power light goes on and off but it does not turn on.it takes everal attempts before i get picture and sound
Does it make a slight popping or cracking sound ? If so remove the back cover and see if the flyback transformer shows any sign of burning or arcing. It is located on the far rt. hand rear side with a red wire comming out of the top and a black one behind and lower than the red one.
Oct 13, 2009 | RCA D52W19 52" Rear Projection Television
I have a rca tv model d52w17 chassis # D416c30WC.
sounds like the flyback if your talking about the lower left when looking at the rear of the set.
Apr 12, 2009 | RCA HD52W59 HDTV Projection Television
Tv shuts off after awhile
DEAR fleming_pj
OPEN YOUR TV AND TRY TO RESOLDER ANY LOOSE CONTACT.
OR CHECK POWER SUPPLY UNIT .IT COULD FIX YOUR PROBLEM.
OK
Nov 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA MODEK D52W17 Cant Get Any Remotes To Work This TV
The remote receiver in the TV is failed. It is possible that a TV repair shop might be able to fix the problem for you
Jun 18, 2008 | RCA HD52W58 52" TV
RCA D52W17 won't stay on.
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
RCA has no sound
well u have a problem in the audio circuits of the tv which includes the speaker itself. but most of the time the audio power output transistor or ic get easily damaged resulting a no sound tv. if u dont have any idea with regards to this, i suggest have it check with a qualified service technician. it will not cost u a lot for sure.
Jan 17, 2007 | RCA F36665 36" TV
Televison & Video Logo
254 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
