Televison & Video Logo
Anonymous Posted on Dec 08, 2009
I have a Sony digital TV. Recently had a power cut and voltage dip - tv was turned on when this happened. Then found we had lost most stations. Retuned the set and only have 19 channels compared to 90+ previously. Swapped another (samsung) TV onto the same aerial and still had 90+ channels. Phoned Sony technical services who suggested it could be a problem with the transmission! Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 09, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
283
Points
Retune of TV sorted problem out - even though I had already done this previously! Problem with transmitter?
1helpful
2answers
I want to know how to check ballistic voltage on a dip tv
    How to test TV Powersupply Review - YouTube
    ? 5:19
    https://www.youtube.com/watch?v=TELvc0thP34
    Nov 8, 2011 - Uploaded by Tampatec
    powersupply Common problems & solutions to fix TV power issues, How to test troubleshoot Sony power supply repair help ...PLS I WANNA THE MANUAL FOR SONY CRT TV MANUAL FOR MODEL .... I can do is check everything out on they power board. an you tell me how to do this on everything?Missing: ballistic ‎dip
    Notes on the Troubleshooting and Repair of Television Sets
    www.repairfaq.org/sam/tvfaq.htm
    Nov 17, 2009 - Low voltage power supply fundamentals; Standby power supplies; Typical TV ..... For more info or if you want to buy one, see DLP TV Showcase." ... is a good chance of repair without access to specialized test equipment and parts. ...... If the bulb lights at full brightness, you know there is still a major fault.
    Dell W5001C 50" plasma fix - Instructables
    www.instructables.com/id/Dell-W5001C-50quot-plasma-fix/
    InstructablesMy buddy's Dell 50" W5001C plasma television conked out one day so I set out trying to fix it. ... Make sure the first thing you do is measure the voltage on the Va test point... I know this is a really old post, but i found a dell 4201c on the trash the other .... I can't or don't want to pay to fix, I may be off to Best Buy for a new TV.Missing: ballistic
    Amazon.com: NEW BALLISTIC PERFORMANCE LITHIUM ...
    www.amazon.com/BALLISTIC.../B005KLOYHE
    Amazon.com, Inc.
    Rating: 3.3 - ‎23 reviews
    NEW BALLISTIC PERFORMANCE LITHIUM EVO2 12V 12 CELL ..... false codes to your bike during the starting process since its voltage will dip in and out.
    ELI5:How do digital devices know how much energy is left in ...
    https://www.reddit.com/.../eli5how_do_digital_devices_know_ho...
    RedditNov 16, 2013 - Want to join? .... ExplainedELI5:How do digital devices know how much energy is left in their batteries? ... A digital device will take this voltage and will look up how much ..... I had a cable tv installer who put little caps on the end of a few .....Electronics such as lithium drill batteries and other battery items test ...
    Do modern TV's (LCD/LED) really need a Voltage Stabilizer ...
    https://www.quora.com/Do-modern-TVs-LCD-LED-really-need-a-V... QuoraThis causes temporary power dips to other electronics, like the LED TV, which in turn affects the TV's processes. In fact, one of the reasons why many LED TVs ...Missing: ballistic
    The First Lunar Landing
    https://www.hq.nasa.gov/alsj/a11/a11.landing.html
    NASAJan 5, 2016 - However, it is often desirable for the engineers to know what the residuals were before .... [Armstrong - "We did landmark checking to check our position over the ground, and that ..... [That is, Houston wants Eagle to use the aft omni-directional antenna.] ... I'm getting a little fluctuation in the AC voltage now.
    Power Rectifiers
    www.myerspowerproducts.com/index.php?option=com...id...
    Medium Voltage AC Power Solutions ... Low Voltage Switchgear ... Low VoltageSwitchboards, Panelboards & Meter Boards · Low Voltage ... Cable Television.
    Searches related to I want to know how to check ballistic voltage on a dip tv
    tv power supply repair
    tv power supply diagram
    tv power supply symptoms
    power supply for sony bravia tv
    tv power supply repair kits
    tv power supply repair cost
    sony tv power supply board
    sony tv power supply problems
    1 2 3 4 5 6 7 8 9 10 Next
1helpful
2answers
May sony tv has sound when you turn it on but no picture
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Have lost all my hd tv stations
Hello
Just reset the TV to factory settings and retune it using auto tuning fuction from the Menu option.
To reset it to factory settings, do the following:
Turn on the TV. While holding down "UP arrow" button on the remote control, press the POWER button on the TV. [The TV will turns itself OFF and then back ON again. Release the "Up Arrow button.
This operation will clear all your customized settings including Paremtial Lock settings.
in otherwords, this is the process to unlock the TV if it is locked.
Retune it by autotune fuction. All the lost stations will emerge again.
Ok.
2answers
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Y sony direct comparator st s444 es 2 does not hold radio stations. Once power has been turned off for more than a couple hours, memorized radio stations are lost. Thank you
You could try looking for a memory retention capacitor on the circuit board. It will be on the board with coils etc. They sometimes are marked on the board. However they look like squashed electrolytic caps. They have a value of between 0.022 and 0.047UF and a voltage of around 5.5 volts. If you see one like that and it's near an IC then you found the trouble, replacement should stop the loss.
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Lost digital signal on analog TV
You do not need to use an RF modulator if you have a LG DR787T. It will output the program on channel 3 or channel 4. If you have another recording machine, I think you may need to re-scan for the stations.
It is also possible that you need to use the remote to switch from the analog (66 only?) stations to the digital stations.
If using a 787, press HOME, select TV & press ENTER, the channel list menu appears. With the highlight on the top of the list, use the < and > arrow keys to select from: TV, DTV, Favorite, or ALL. This lets your pick whether you want to see digital, analog, favorites with the "HEAR" symbol, or all stations.
tom
THIBSRUS:
I think that there is a selection on the Panny that works much like the TV/VCR selection on a videotape recorder. Your machine is receiving and decoding digital stations, as you stated you can see them on the menu screen, but is not passing them through to your TV set for viewing. To use the Panny as a tuner for live TV shows, or actually, programs currently airing, you have to tune the TV to channel 3 or 4, or, if using the Red/White/Yellow connectors, the proper video input selection, AND turn the Panasonic on, and have it sending the programs it is receiving out on the antenna connection or the video/audio out (RWYellow) connections. It is really a matter of selecting, on the Panasonic, whether it passes through the antenna signals, or the digital signals that is is receiving.
tom
1helpful
I have lost digital ITV and all the digital stations on my Sony Bravia.
Perform a master reset by doing the following:
Turn the TV On
With the original Sony remote, hold down the "up" button in the 4 direction buttons (uo, down, left, right)
While holding down the up button on the remote, press the power button on the TV (not the one on the remote)
The TV should reset and restart, asking you which language you wish to use.
After choosing the language, let the TV do an auto program and you should be OK
Please rate this solution. Thanks!
3helpful
7answers
No picture but has sound
i have a new hd tv i have sound but no picture from with a indoor arieal what can do to check it
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
