E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
SOURCE: Amtrol Boilermate makes whining noise
did you oil the circulating pump? this must be done it might be low it will come on when the boiler comes on
SOURCE: no hot water have amtrol boilermate
There is a device on the boilermate called an aquastat which controls the flow of hot water into it. Replace that and you should be up and running again. Joe.
SOURCE: ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
SOURCE: if the amtrol boilermate water
If the area it is in is heated it will not freeze any more then the water piping would.
