Question about NorStar M7310 Corded Phone
How do I program the speaker to work?
We had a power failure and now the phone isn't working properly. The speaker isn't working and line 3 rings on the speaker button.
Posted by angelinsuran on
Carl Navarro
  • NorStar Master
  • 2,460 Answers
You have lost system programming. Unless you are well versed in getting into your system with the installer password, you need to call a Nortel service tech. The older systems have a battery backing up the memory and when it dies, your system crashes. It's really obvious, because it goes back to the default of only 2 lines working and all the buttons become defaulted.
Entire systm programming is beyond the scope of this forum. I do have a CICS programming sequence on my website http://www.public.carl.airpost.net/Nortel/CICS_Programming.pdf
It would be unlikely that your system is a CICS, but this is an idea of where the programs are and what level you need to access them.
Carl
Posted on Dec 08, 2009
Why can't I answer a call on line 2?
Confirm the extension # you are working with and that the line 2 key is line 2. do this by pressing feature *0 and the pressing the intercom key, observe the display and then press line 2 key and view display. then go back in the programming and view line 2 apear&ring, change it until it is apear&ring, then release and check for working again. If this dont work check to see if line 2 is programmed as a private line.
Jun 17, 2015 | NorStar T7316E Corded Phone
We have a 4-line system in our office, but it is not working properly. For instant, when line 4 rings...it only comes into one of the phones. All lines are working properly with dial tones. If we would...
Now here's a conflict. Does line 4 work on any other phone where it doesn't ring? You say all lines are working properly wiith dial tones, tnen you say you can't pick it up from another phone.
I don't think these phones have "private lines", but the dial tone comes from the 2nd RJ-14 jack on the wall. On every phone, you could swap the plugs so that line 1 comes into line 3 and line 3 comes into line 1 (you'll lose the intercom) and see if you get dial tone on line 2 which will be the phone that works line 4. The point being to determine if you have a wiring issue or a programming problem.
Carl
Mar 21, 2011 | RCA 25423RE1 Phone
Caller id not working on only 1 phone
It's a good bet that that telephone doesn't ring therefore the system won't pass on the caller id information.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 26, 2010 | Avaya 700340193 Corded Phone
Can't reset time/can't answer line two from my phone
To change the time, the code is "feature**time" The password is "basic". As for the line 2 issue...press "feature*0" then press each line button and see if line 2 is programmed on your phone. If it is there, is it programmed to ring? If you can access the line outbound, then you should be able to push the button to answer it inbound. Hope this helps.
Bill C. www.dyna-tech.us We offer remote programming and tech support for Norstar CICS, MICS and Call Pilot 100/150.
Apr 05, 2010 | NorStar M7310 Corded Phone
I work for a small non-profit organization and we have a Lucent phone system - the problem is that when ANY call comes in on the mail line - it rings on everyone's phone. How can I fix this so that it...
Press the right hand intercom once. The display should say Centralized Programming2_bing.gif.
Dec 18, 2009 | Lucent PARTNER18 Corded Phone
Cancelling phone lines.
The phone system will still work but if you use 9 to dial out, it will still try and grab the lines. You should have them removed from trunk programming in order to do so. ldtsnj,com can help
Apr 20, 2009 | NEC Electra Elite 32D-1 Corded Phone
M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Mar 04, 2009 | NorStar Meridian M7310 Phone
Samsung Prostar 816
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Aug 30, 2008 | Samsung Prostar 816 Phone
Phone ringing after power failure
I believe you have to reset the intercom system, meaning you need to reassign one or all of the phone's intercom numbers. To assign intercom # ( found on page 10 of the manual which you can download online)
1 Do NOT lift handset
2 Press the following 3 buttons (in order) PROGRAM, STAR, and then POUND
3 Enter two digits (the number you want the phone to be)
4 Press the INTERCOM button and you will hear a tone - then youre all done.
Aug 03, 2008 | AT&T 954 Corded Phone
Norstar Phones - Turn off ringer on phones
You have to go in to programming and set the phone in the shop to ring on line 3 only and the phones in the office to not ring on line 3.If you don't know how to go in to programming please inform me.
May 14, 2008 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
220 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
