Want to improve screen resolution on notebook. make text and pictures clearer (how?)
Anonymous
    New Friend:
  • 89 Answers
Right click your desktop and choose properties, in there you are able to change the resolution.
change it the a smaller resolution to get larger icons and start menu, on some models this may produce an automatic scrolling desktop i.e. when your cursor is near the top of bottom of the screen it moves up or down.
this will not change the resolution in your internet browser for example, you will have to use the View > Zoom option in internet explorer.
Hope this helps. Please Rate
Posted on Dec 08, 2009
Anonymous
  • 763 Answers
I ma not sure about your operating sytem installed but
for windows XP:
right click on any space on the desktop,select properties,then click on the tab called setting and change the screen resolution as you want. ( this will hold true for windows server 2000,2003 too)
for windows vista  & windows 7
right click on any space on the desktop,select screen resolution and change the resolution as you like.
if you want to decrease or increase icon size
right click on any space on the desktop,select view and change the setting from small to medium or large.
Note : all this will work perfectly or not work at all only if have installed the video graphic card driver in your system.
Testimonial: "Thanx all done"
Anonymous
    New Friend:
  • 5 Answers
Running vista/win7 -- right-click desktop -> personalization -> display settings -> drag thte slider up.
running winXP -- control panel -> display settings -> drag thte slider up.
if the slider is maxed make sure you drivers are current and "accesability" options defulted
3answers
tip
How to set your Desktop Screen Resolution?
Greetings, Welcome to Fixya!
So you need to adjust your Desktop Screen Resolution ey!!! It's a good thing you visited as today we are going to discuss just that.
We will be using our monitor to it's full potential, which will ensure we see the best picture our monitor can provide.
Follow the steps below:
1.)Right click on your desktop screen.
2.)A rectangular menu box appears.
3.)Select Properties, found right at the bottom of the menu box.
4.)Select the Settings Tab, found on the top right hand side of the window.
5.)On the bottom left hand side you will notice a slider bar under the heading Screen Resolution.
6.)Move this slider to the left to decrease the Screen resolution, less detailed, move the slider to the right to increase the Screen Resolution, more detailed.
7.)Ensure that the colour quality is set to highest, to give a more detailed and clearer picture!
Below: The window, see the slider bar on the bottom left and the colour quality on the right!
That should do the trick!
Now you will enjoy all the detailed, crisp, goodness that your monitor has to offer.
Thanking you
Till next time!
damnor01
on Dec 14, 2010 • Computers & Internet
How can increase the resolution on a photo
Technically you can't improve the resolution. Photoshop or similiar photo editing programs can improve the picture to some degree .
3answers
I want to know how to make the page type (font size) bigger so I can read the pages i browse easier to read. Print on the pages are to same. thank you
right click anywhere on desktop>properties and set the screen resolution to a smaller value.
To change your monitor's resolution
1.
Right-click the desktop, and then click Properties.
2.
In the Display Properties dialog box, click the Settings tab.
3.
Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4.
Click Apply to have the new resolution take effect.
5.
If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6.
Click OK.
Microsoft Windows XP changes the resolution to the settings you chose.
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • 2helpful
    2answers
    Everything is blury have to set screen resolution to 800by600 pixels to try too make any thing out.
    Connect the monitor to a laptop -- is it still blurry?
    If so, then the monitor is the problem.
    If not, then your computer (the video-card?) is the problem.
    Photos not clear on webpages
    It can be the problem of your computer screen resolution. Few things to cross check with your system
    1) Check the screen resolution supported ( approx. 32 bit 1024x768)
    2) Supportable graphics driver.(recommended get the latest driver and install it again)
    3) check the IE Text Size under view menu it should be MEDIUM
    1helpful
    Can not change the number of images that can be taken
    Ok, this is a very easy procedure..
    While in picture taking mode, press the set button and it will activate the controls to choose the image resolution. If you select a higher image size or number, it will improve your quality of picture as the number of the resolution you choose gets higher. Simply use the side scroll and the up/down scroll on the back... that will do it for you!
    Laptop display is 1/4" in from the left?
    1.
    67366-click-properties.jpg 2.
    3.
    Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor’s resolution, making text and pictures appear smaller.
    67366-drag-screen-resolution.jpg 4.
    67366-click-apply.jpg 5.
    6.
    Click OK.
    In the advanced tab you can center the screen
    LB
    Computers & Internet Logo
    Ekse
