Question about Vehicle Parts & Accessories
I have an autowatch touch key immobiliser , that says it's armed (led flashes slowly), but will start regardless of whether i use the touchkey or not. i have tried re programming using the 5 digit code, and still no difference.
Posted by boosimms on
Don Reiman
    Guru:
  • 773 Answers
If its newly installed the ignition interuption relay may not have been installed. Either that or it has been hooked up worng.
only other thing you can do is check the code.
To check if you have the correct code for programming follow these instructions:
  1. wait for the alarm to immobilise itself – IE the LED flashes slowly
  2. Turn the ignition on the LED will be constantly on,
  3. Turn the ignition off, the LED will now flash, count the flashes for the first number in the override code. For example if the first number is 3, count three flashes of the LED. When the LED has flashed the amount of times that corresponds to the first number of the code turn the ignition switch on.
  4. Turn off the ignition and count the flashes for the next number of the code and so on until all the numbers in the override code have been entered.
  5. If the code has been recognised the LED will flash very quickly for a few seconds, you are now in programming mode and the alarm is also disarmed.
  6. If the LED has not flashed quickly - start again from the beginning.
If the number is ‘0’ count 10 flashes of the LED.
Posted on Dec 08, 2009
  • Narutokage Feb 25, 2012
    Hi, thank you for this answer, I could turn on my engine :) So I have a question: I have the auto watch immobiliser 629Ti already installed when I bought my van. All worked fine but actually my key is not recognized anymore and I don't know why! I have only one key and I would like to know what can I do? I can start my engine with the pin code but it's very embarrassing to make this process all the time.. Can I desactivate the immobiliser or reprogram my only key? I apologize for my English and thank for your answer
  • Rob Rhind
    Rob Rhind Mar 06, 2019
    English is perfect and question perfectly reasonable. I have the same issue so a shame that this has sat unanswered for 7 years.
How do i by-pass an imobilizer in a vt holden
you could leave the key in ignition in the on position for about 10 to 20 minutes this over rides immobiliser so you can start vehicle. the red immobiliser light that flashes goes out when you can start it. the light is the red LED next to the trip computer buttons
Oct 14, 2013 | 1999 Holden VT
Hi, We have a renault megane dynamique cabriolet. The distributor belt went recently so we replaced the engine for a used renault megane dynamique hard top. Worked fine to begin with, then suddenly one day...
To check to see if the immobiliser is causing the car not to start there is a small red LED in the centre of the instrument panel normally with the Car locked the LED light should be flashing everyone second this is normal behaviour, Now with the key in the ignition and ignition on normally the led light will go out giving the immobiliser authorisation to start if in this procedure the LED light is flashing rapidly then there is a problem with most likely the key if you have a second key I suggest you test it,
Mar 17, 2010 | 2003 Renault 181
Does my gilera runner vx 125 have an immobiliser
can gilera vx runner 125 immobiliser be by passed 4 stroke
Jan 25, 2010 | 2005 Gilera Runner VX 125
Broken Sensor Sterling Touch Immobiliser
There are 4 wires going to the touch pad unit which has an LED in it. The unit has 4 pins (or legs) to which the wires must be soldered. As you say, there are two blue wires plus a red and also a black - although as you also correctly observe, only three wires are present (blue, red and black) in the connector at the other end of the loom which plugs into the control module.
The blue simply splits two ways within the loom, and these are earths. The black carries a pulsing voltage to drive the LED, and the red (which should measure a constant 5v on a voltmeter) is an input which senses when a key is touched on the pad.
Use a continuity tester or ohmmeter to establish which of the four pins on the touch unit connects to the CENTRE pin of the touchpad. Solder the RED wire to this pin. (Best to start by putting some heat shrink up the wire as the pins on the touch unit are quite close together and there's not much to stop them touching.)
Again using the continuity tester (or ohmmeter) establish which of the remaining three pins goes to the OUTER ring of the touchpad. To this, solder one of the BLUE wires - it doesn't matter which one. You must however get the wires to the touchpad the correct way around in order for the key to be read.
You're now left with one BLACK and one BLUE wire which drive the LED, and two pins on the unit which have no connections. The LED will only light when you get these the correct way around. You will not do no harm if you connect them the wrong way round - the LED will simply remain unlit.
One you have soldered the BLUE and the BLACK wires in place so the LED is flashing, simply test your work by touching a key on the touchpad. If all is well, the LED will light continuously for a period and it should be possible to start the car.
Sep 24, 2009 | Vehicle Parts & Accessories
Immobiliser is not turning off and not allowing the engine to start
is it a stick immobiliser?
If your vehicle does not start and the LED continues to flash while the Ignition is 'ON', this means that the Immobiliser system has not recognised the transponder stick.
Simply turn the Ignition 'OFF' then back 'ON' again. If the Status LED continues to flash, move the transponder stick closer to the key barrel until the LED stops flashing and turns 'OFF'.
If the transponder stick on the key ring does not disarm the immobiliser or the
transponder stick is misplaced, you can override the system by entering a 5-digit override number. Each vehicle has a unique 5-digit override number. This number is recorded on the
customer’s owner’s manual. If the customer loses their owner’s manual / override number, the number can be found by locating the vehicle’s Daewoo Stock Number (D.S.N). The customers override number is the last 5 digits of their D.S.N.
Overriding the system using the example 5 digit code 2,1,0,6,2
Important Note: 10 flashes of the Status LED represent the number ‘0’.
1. Remove the Transponder from the Key Ring.
2. With the system armed (LED flashing slowly) Turn the ignition ON/OFF 5 times, with the final position being off.
3. The LED will turn solid red for 2 seconds and then begin to flash.
4. When the LED flashes twice (2), turn the ignition ON. (number 2 was entered)
5. Turn the ignition OFF and wait for the LED to flash once (1) and then turn the ignition ON. (number 1 was entered)
6. Turn the ignition OFF and wait for the LED to flash ten (10) times and then turn the ignition ON. (number 0 was entered)
7. Turn the ignition OFF and wait for the LED to flash six (6) times and then turn the ignition ON. (number 6 was entered)
8. Turn the ignition OFF and wait for the LED to twice (2) and then turn the ignition ON.(number 2 was entered) The LED will turn solid red, which means the system is now overridden and the vehicle can be started. If an incorrect number is entered in, wait 11 flashes then start the procedure again.
NOTE: This is a one-event override. Once the ignition is turned off, the vehicle will passively immobilise after 30 seconds. If your 5 digit override number does not override the system, the chances are that you entered the wrong number. If this is the case, you’ll need to re-enter the override number
and try it again.
Jul 13, 2009 | 1999 Daewoo Lanos
FTO Toad immobiliser
If you require a transponder in order to start the vehicle, it could be a few problems, could be the immobilizer transponder fob, or the immobilizer antenna, or even the immobilizer brain or relay. Few steps to tell, if the LED light doesn't go out for the immobilizer its the transponder fob. If the light does go out then it could be the antenna, brain or relay. These are the problem areas that can be diagnosed.
Oct 04, 2008 | Car Audio & Video
Cobra immobiliser key
After ages searching finally found this on the Cobra site.... A8510 KEY PROGRAMING Ensure the immobiliser is disarmed :- 1) Switch the ignition ON and OFF three times then back to the ON position within seven seconds. 2) The LED on the dashboard will light up signaling the unit is in programming mode. 3) Touch an already programmed key onto receptical, the LED will extinguish for one second 4) Repeat step 3 for all other keys (Max of 4 touch keys) 5) To exit programming switch off the ignition key (unit will automatically exit programming after four keys) NOTE :- 1) Programing procedure can only entered with the system disarmed. 2) If all keys have been lost the system will need to be replaced
May 24, 2008 | 1994 Land Rover Discovery
Cobra 8510 immobiliser fitted to my ford excort rs turbo
Wheelsnboots
When you say the Immobiliser is broken... Do you mean the touch key?
The 8510 touch key is prone to the internal contacts failing. If you open the case up and reconnect it then you should be able to disarm the immobiliser
You should have two touch keys so try your spare on first.
Be warned... You will need 1 working touch key to program a spare or the system will lock out and will need replacing
Hope this helps!
As for Sutty
Sounds like the system has lost power if the LED is not flashing. Have you made sure cars the battery is not flat?
May 05, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
997 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
