Question about HP Compaq Business d530 Ultra-Slim PC Desktop
How much i can upgrade my d530 ultra slim desktop RAM and HDD
Posted by sushil796 on
Chris Hingee
  • HP Master
  • 32,281 Answers
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
how much i can upgrade my d530 ultra slim desktop  - dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Posted on Dec 08, 2009
My hp d530 usdt problème ne reconnaitre plus mon lecteur dvd
i want hpcompaq d530 usdt (pb590a) micro up date fot the prosesor 3.0ghz,512,800 please solve my problem now my email is [email protected]
Mar 16, 2010 | HP Compaq Business d530 Ultra-Slim PC...
Remval of power supply from hp d530 compact desktop
there are 4 screws on the back of your computer that will release the powersupply at that point you should be able to just slide it out keep mind were you unplug things
Company site http://www.attechcomputers.co.cc
Jun 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
LED light is orange but computer is on.
it sounds like you may have overloaded the PSU, best thing to try would be to take out the dvd burner and and try booting again, if this doesn;t have any affect it may mean you need a new psu (power supply).
Mar 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Hp530 Ultra Slim starts and stop after 3-20sec
I have had this once before, and then it was one of the hard disk cables which was interfering with the fans inside the case. In my PC it was the PSU fan which was being halted. Try moving the cables around inside the case and ensure none of the corners where they are folded are protruding into any of the fans.
Feb 03, 2009 | HP Compaq Business d530 Ultra-Slim PC...
My computer d530 hp compaq
Your video card drivers are most likely the culprit. Go to HP.com, find the drivers and downloads section and get an upgraded video/graphics driver. Either that or you need to upgrade the video card in the computer, not sure what kind of slot or if one is even available for the d530.
Jul 14, 2008 | HP Compaq d530 Ultra Slim PC Desktop
Cpu, hd, mem from this d530 slim...
*check the model number of the motherboard and replace the same so that it support your system
Jun 25, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Won't turn on
Hi
The problem is overheating please remove and replace the processor fan.
Jyo
Jun 20, 2008 | HP Compaq Business d530 Ultra-Slim PC...
5 beeps HP Compaq d530
5 Beeps
CPU or motherboard problem
Apr 11, 2008 | HP Compaq Business d530 Ultra-Slim PC...
HP D530 SFF desktop
it is depend up on the power supply connector and it will give the output according to the smps you can do one thing try with installing other fan and see is it in perfect rotation. bye
Oct 09, 2007 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq Business d530 Ultra-Slim PC Desktop Logo
571 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
