Question about Canon imageRUNNER 8500 Copier
Vinod canon ir6000 error e00061-00001 i cant
canon ir6000 error e00061-00001 i cant solve htis err
Posted by xerotechcopi on
  • Anonymous Mar 25, 2014
    how can i solve the problem with E602-0001
Anonymous
    New Friend:
Hai,one ir6000machine in oneand most problem eo61-01 please solution in this problem thnk you.
Posted on Jan 13, 2010
Anonymous
    New Friend:
  • 82 Answers
There is a sensor in the drum unit that may be dirty/faulty. If you get the drum unit out, its on the top. Clean that up and see if continues. If you are not a technician, you should get a Canon technician in.
Posted on Dec 08, 2009
Ad Bambhaniya
    New Friend:
    Problem Solver:
  • 17 Answers
1-change primary carona wire
2-drum sensor
3-clean laser mirrors
Posted on Feb 19, 2015
Canon ir6000 error code e000012 xerox machine not running solve problem
E000012 Clock pulses fail to be generated or the PLL lock is released due to a fault in the drum motor, etc.In case the drum drive motor exists in addition to the main motor, this code refers to an error of a motor which drives mainly other units than the drum.
Canon ir5000. How do I correct error 732?
These are all list of error code in Canon iR5000/iR6000 more to come, i hope your machines works fine and never get error.
  • E000
Main cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
  • E001
Main cause: The main thermistor (TH1) has a short circuit.The sub thermistor (TH2) has detected overheating.The SSR is faulty.The DC controller PCB is faulty.Mode of detection:0001 The main thermistor or the sub thermistor has detected about 230?C or higher for 2 sec.0002 The main thermistor has detected 230?C or higher (hard circuit detection)0003 The sub thermistor has detected about 236?C or higher. Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Canon IR6000 shows error code E000061-0002
this is problem Error E000061-00021 how to solve plz send Answer
3helpful
2answers
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
2helpful
ImageRUNNER 7200 Copier: hi I'm Akar I have a canon ir6000 copier my...
The problem is with toner section. The copier cant get toner to toner unit or the toner motor is faulty.
In one case eaven the main pcb caused the problem.
I would try to replace toner hopper assy.
call service.
6helpful
3answers
Getting a problem with a canon ir 6000 error code E 350-001
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail [email protected] ty
6helpful
2answers
Not able to start my machine dure to error below
The SSR has a short circuit. The DC controller PCB is faulty.
0000 The SSR used to drive the fixing heater is found to have a short circuit
(hard circuit detection).
The error must be reset in service mode (COPIER>FUNCTION>
CLEAR>ERR).
Canon imageRUNNER 8500 Copier Logo
old marine
old marine
Ekse
