Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony wega kf-ws60s1 , standy by lamp flashes 6 times, have replaced the lamp but standby lamp still flashes 6 times...............help please!!!
Posted by coady007 on
Paul
    Sergeant:
  • 381 Answers
Thermal fuse by lamp is open. replace it.
Posted on Dec 08, 2009
Jamie Fodor
    New Friend:
Where is the fuse located
Posted on Nov 02, 2011
Sony Grand WEGA KF-60XBR800 Service Manual
Lamp/Bulb A1601-753A (XL-2000U) .
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KF-60XBR800
Apr 29, 2014 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Wega KF-WS60S1 when turned on begins with 5 green flashes then 6 red flashes
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 09, 2017 | Sony Televison & Video
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Sony wega kf-ws60s1 , standy by red lamp flashes 4 times, help please!!!
standby 4 time flashes shows error of Fan that is not running in TV.
Your TV has 4 fans and any one is not running due to some reason. Check fans are not caught wires or some thing that causing problem.
Qualifier tv tech will require to inspect TV if you are not comfortable working in TV.
Dec 16, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KF-50WE620 - 5 Flashes
5 blinks code shows problem with Lamp Drive circuit (ballast supply) and / or Lamp itself.
How old is this TV and have you replaced lamp before?
May 31, 2009 | Sony Grand WEGA KF-50WE620 Television
Got a sony grand wega kf-42sx300u tv. the standby indicator on the tv flashes
Im afraid my friend the lamp needs replacing (model: XL-2100E), if you have a hunt on google you will be hit with the pain of the cost... like me :(
Aug 11, 2008 | Televison & Video
Sony KF 50WE610
The audio should not work if the lamp has expired, but it would be the best place to start. The led flashing 6 times is a complete other issue, and needs the thermal fuse changed.
Mar 09, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
