Kodak EASYSHARE G610 Thermal Printer Logo
Posted on Dec 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recive a message to replace color cartage and it will not print my pictures
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Dec 08, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557634
Points
31058
Replace the colour cartridge,
or use Windows to configure your printer to print "black only".
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Won't print color. Color inks are full, cleaned jets, but still won't print in color.Black ink prints.
Due to not used your cartage the opening of the cartage lid become freeze so put it for some time below running water and then try to print it will work
Spotty color print
first of all you can remove your color cartage
and check this cartage to simple page
which color is appers
after that refill the cartage from the serge
3ml
3 color in the cartage and every color every point you can refil
2helpful
Picture color is way off when printed. For
Two things i would suggest in case get your printer serviced and get cartages refield with good quality of ink..
2helpful
Smsung 4521 printer error toner empty
If we reffii samsung tonner some time these printer gave that type message. it means to re set the cartage. we should reffil cartage before reciving that message.while we get tonner low message. your cartage have may be green cheap or fuse. change it then your printer work properly. chaingining cheap or fuse can be use after reset.. so change it re old them.
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Color ink senser will not ingage
What was telling you it was the sensor, did the printer give you an error message. Is this a standalone unit or hooked to a pc?
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
