Whirlpool DU943PWK - Multiple Color Built-in Dishwasher Logo
Anonymous Posted on Dec 08, 2009
Two problems: soap cover and seal?
Two problems: soap cover won't stay closed, and now leaks down front on one side when running. do i need new seal?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 08, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
98
Points
Door leaked because of a plastic bearing ($4.10 part) on the lower arm causing water inside to surge and splash out the vents on the bottom of the door. Soap cover problem was a corroded spring caught on a plastic part inside the door panel. The spring actually broke and now seems to work fine because there was another spring helping to do the same job that is now allowed to work.
2answers
My duet front load washer is licking water in front left side have any idea and how do u take off the bottom front cover
there are three screws under the front of the panel. make sure its not leaking from the door and running that way. if the bellow or door seal is damaged or bent or torn it will leak. please dont forget to rate me thanks
3helpful
Oil leak from rocca cover or cam seal
I don't understand what a rocca cover is, but your two most common oil leak locations are the front cam seal behind the timing belt pulley and the rear cam journal plug in the valve cover.
For a leak at the front, next time you replace your timing belt, unbolt the pulley, extract the old seal with a sharp hook, and press in a new seal. Be sure that the new seal is pressed in straight, and grease the lips before you press it in. Often, the front crankshaft seal fails about the same time, so replace that one as well while you have the timing belt off.
For a leak at the rear, reach back there behind the valve cover with solvent on a rag and clean it up nice and dry, then coat the edges of the rubber plug liberally with silicone seal. Allow to dry. Replace the rubber plug next time you have the valve cover off, but use some silicone seal to secure the new one so it stays in place and won't start leaking.
These cars are prone to valve cover gasket leaks, so expect to replace the valve cover gasket every few years. This is a particular problem if you use synthetic oil.
Any time you have problems with oil leaks, suspect that the crankcase is pressurizing due to a plugged ventilation system. Check the flame arrestor to make sure it is clean and clear. The flame arrestor is between the legs of the intake manifold, generally in a hard-to-get-at location. Also, blow down the hose below the flame arrestor to make sure that the oil mist separator box on the side of the engine block has not plugged up with sludge.
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
2answers
Hi i have a 1994 dodge caravan it is leaking oil can this be fix im worry that we would have to save money for a van for my kids thanks
The Chrysler minivan products all had leaking problems. I have had 5 or 6 different Dodge or Plymouth minivans from 88 to 99. How bad is it. The most common thing is Valve cover leaks. Front and rear seals in the engine leak as well as the oil pan gasket. If its leaking a little bit at a time open the hood and look at the front and rear of the engine. Do you see grease and oil that has gone down the sides of the engine? Do you see a lot of grease on the engine with some clean streaks going through it. You may be able to see where its leaking from. If you know someone that knows what their doing have them change the leaky gasket/s. If not you can probably have it repaired for less than buying another van unless other things are seriously wrong with the van.
Hope this helps... Dale
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
4helpful
2answers
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
During the rinse cycle I see a trickle of water running down on the left side of the machine. The leak does not happen on every load. Any thoughts on the cause? Do I need a new front gasket? Thanks
The left hand side is where the soap dispenser sits
Remove the drawer clean out the pipes leading to the drum and give it another test
If it still leaks then remove the top and run a cycle , watch the hoses for splits.
Be careful and cover the programmer area with newspaper before you apply power
2helpful
3answers
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
2answers
Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
