Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR-M550 with a paper tray error F3-12
I am working on a sharp AR-M550 with a paper tray error F3-12. Tray 1(paper tray desk trouble). I took the cover off of the front of tray 1 so I could watch the elevator. The one on the right side works fine, but the left one does not move up. I switched out the drive motor and gears from the right side to the left. It did not help. I then switched the small board that has the two sensors on it and that did not help. I took the gearbox apart and watched the worm gear and it would not even try to turn when I blocked the sensors. The right side did turn.Someone please help. I have spent 3 hours on this one.
  • Anonymous Dec 09, 2009
    There is no service log. And I said in my post that I swaped all of the sensors, boards and motors from the 3rd tray. All of the gears are good.
    Did you not read my post. I am a copier tech. I just don't know a lot about sharp. I am certified on minolta and kyocera. You did not read my entire post.
Anonymous
    Guru:
  • 73 Answers
If the message "CALL FOR SERVICE CODE:**-**"(Note) appears in the touch panel, turn off the main power switch and the power switch, wait about 10 seconds, and then turn the main power switch and the power switch back on. If the message still appears after turning the main power switch and power switch off and on several times, it is likely that a failure has occured that requires service. In this event, stop using the machine, unplug the power cord, and contact your Sharp dealer.
Note : Letters and numbers appear in the "**-**". When you contact your Sharp dealer, please tellyour dealer what letters and numbers appear.
Hope this helps.
Have a good day.
Posted on Dec 09, 2009
Vincent G
  • 2,363 Answers
When I first arrive to any service call the first thing I look for is the service log.
Locate the service log on the rear,side or inside the front cover.
Check the last error code and corrective action.
F3-12, Paper does not lift in the tray
Identify how many lift tray is inside your machine.
Check each sensor(s) for smooth operation.
LOOK inside for crack plastic on the lift tray.
Sensor can be defective (non-operational) and no cutting off power to the motor and damage the motor,metal frame and plastic tray.
Use a small METRO VACUUM with a clean bag,
Vac the interior of the unit,
Look for fragment of plastic tray or sensor arm inside the vacuum bag.
Pass the information to a Sharp authorize shop.
  • Vincent G
    Vincent G Dec 09, 2009
    Use a vacuum and clean bag to clean the interior of the Sharp.
    Inspect the bag for fragments,
Anonymous
    Scholar:
  • 74 Answers
Hi this sounds like you may have a faulty sensor board, i assume the sensor you blocked was the upper limit sensor, if so then i would expect this to stop the motor, check the drive motor for bad or broken joints as this is quite common, also please trace back the wiring to the I/O board and check all the plugs ar seated correctly.
You can also run an input/output check on this machine to make sure the motors are turning correctly.
I suspec you have either a faulty photosensor, motor or seized lift, check the engaging drive gears for cracks.
1 Related Answer
Anonymous
  • 54 Answers
SOURCE: sharp AR-M550 with a paper tray error F3-12
1. Start and end of simulations Note: The "PAUSE" key in the descriptions means the "INTERRUPT" key. Simulation IN The Simulation IN mode becomes only available from the Copy mode screen. In the simulation mode, printer operation is inhibited. Printer operation is also inhibited in either of the Aging mode or the Adjustment Copy mode. The printer selection key is disabled, too. By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation main code input screen appears. * If the interval between any two key operations is more than 5 seconds, the entry into the simulation mode is canceled. (Ref.) 1 ~ 9: Loading/ sensor checks 10 ~ 19: Resetting troubles 20 ~ 29: Counter/mode setting 30 ~ 39: Sensor activation checks 40 ~ 59: Adjustments 60 ~ 69: Digital readout and printer Simulation OUT The simulation can be terminated by pressing the [CA] key. 2. Simulation main code input screen SIMULATION NO. _ INPUT MAIN NO. AND PRESS PRINT SWITCH 1 If any trouble has occurred when the trouble code is requested, the 7-segment readout displays the trouble code (main only). [Note] The trouble code is canceled when the copier enters the simulation IN mode. [Note] The 7-segment readout becomes blank when the copier enters the simulation IN mode. 2 Only the [PRINT] key LED comes on. [Note] The [PRINT] key LED is usually OFF. It comes on when the copier waits for the [PRINT] key to be turned ON in the simulation mode. 3 The main code input area (2 digits) waits for the input of a main code. [Numeric Key]: Main code input [Note] Codes are entered in the ring format. [PRINT]: Sets entered data. [C]: Clears entered data. [CA]: Terminates simulation. [Others]: Cancels (ignores) entered data. 4 If a simulation has a sub code, it should be executed on the sub code input screen; a simulation does not have a sub code, it should be executed on the simulation execution screen. 3. Simulation sub code input screen
Posted on Jan 14, 2010
Testimonial: "Great"
When i try printing with my sharp ar-m205, it automatically reselect bypass tray and gives error "check bypass tray: out of paper or missfeed". But the tray i originally selected is tray 1.
Size mismatch between your print request and the size specifed for the paper in the tray. these trays do not auto-read, you have to tell the copier what size is in the tray
Nov 01, 2013 | Sharp AR-M205 Copier
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
F3-12 Paper tray desk trouble
check the paper trays ensure guides are set correctly and check behind the draws no paper stuck behind, also remove any paper from draws which is considered storage paper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 14, 2012 | Sharp MX-2300N Color Copier
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
I have an AR-m237 that tray 1 will not pull paper, tray 2 works fine
is tray 1 recognized if not the little switch on the back of the machine behind tray one in blown, other wise you have to see if the rollers turn
Jul 08, 2010 | Sharp AR-M237 Copier
Dec 08, 2009 | Sharp AR-5320 Black and White Copier
Sharp ARM550N error F3-12
You will need to reset the error code. Try crop 15 or 14.
Dec 08, 2009 | Sharp Office Equipment & Supplies
Tray 1 paper not recognized M620n
Are you getting a error code? I would look behind the paper tray for a piece of paper behind the tray? Good Luck
Nov 15, 2009 | Sharp AR-M550N Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
2,553 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
