Question about Amana ALG331RAW Gas Dryer
The gas dryer is not getting hot enough to dry clothes have to run it double the time to get clothes dry-exhaust not blocked-igniter is working-there is a flame-checked dryer heat setting manual knob with ohm meter-its ok-checked high limit thermosat-ok.Once the temp comes up and the flame shuts off it seems that the dryer runs for a long time before the flame comes back on.
Anonymous
    Scholar:
  • 39 Answers
In light of everything you checked, it sounds like you have a bad set of coils on the gas valve. When they go bad, it can take a long time between cycles. Hope this helps!
Posted on Dec 08, 2009
Testimonial: "thanks-the hunt continues"
Anonymous
  • 75 Answers
You might want to replace the thermacouplar. Sometimes when they are going out , all will appear to be alright but as you stated it takes a long time for the flame to come back on. This sounds to me like the thermacouplar is going out.
Testimonial: "thanks I'll try that"
Have samsong front loader dryer running for short periods of time and it is shutdown and will not start for short periods of time
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Jan 19, 2016 | Dryers
Gas dryer heats up runs about 3-5 minutes then quits. Have cleaned all filters, exhaust and sensor with problem continuing
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!!
Oct 12, 2014 | Bosch Nexxt 500 Plus Dryer
GE Spacemaker Dryer DPXH46 (gas) runs and blows but stopped heating. Gas supply is good. How do I troubleshoot the igniter?
Thermal Fuse
Air Flow and Heat
Warning
Oct 05, 2014 | Dryers
Our propane kenmore dryer is not igniting. How do you fix it
GOD IS GOOD !!!!
Thermal Fuse
Air Flow and Heat
Warning
Oct 04, 2014 | Dryers
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Thermal Fuse
Air Flow and Heat
Warning
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
Gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Aug 18, 2014 | Jenn-Air Jenn Air Clothes Dryer LSG2700W,...
Flame keeps going out after 5-10 seconds
Thermal Fuse
Air Flow and Heat
Warning
Aug 18, 2014 | Dryers
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Thermal Fuse
Air Flow and Heat
Warning
Jul 19, 2014 | Kenmore Dryers
I dont' think it is drying my clothes. It's not getting hot?
gas or electric? if electric then probably either plugged exhaust hose or bad element....if gas then probably either plugged exhaust hose or temperature shut off switch or 1 0r both magnets on the gas valve,listen for the burners to ignite,if the burner shuts off afer 1 minute of running then double check the exhaust hose,the burner should run lots longer if working right.
Sep 10, 2009 | Maytag Dryers
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Amana ALG331RAW Gas Dryer Logo
1,057 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
jdthefixer
Are you an Amana Dryer Expert? Answer questions, earn points and help others
